Results 1 to 17 of 17
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Getting Paranoid!!
    First of all I have a 1998 S4 , first Avant S4 ever made in europe as you see also old airco and old dash .
    after waiting weeks for my JHM shifter to arrive + having to pay 95€ (150$) extra to customs I just found out there is no fu**ing way this thing will fit my car. I cannot unscrew all the bolts, the harnas is totally different with the one JHM sent me and I have a aluminum cage surrounding my shifter
    + the opening is even smaller then the B5 A4 from the shifter bushing upgrade movie from JHM as you see in the pictures I even cannot reach all the screws[O_O]
    pfff this is really depressing, I hate the way my car shifts and now it seems I payd 400€ for something I can't use
    here are the pics:
    here you can see the aluminum cage surrounding the whole shifter.unscrewing those 2 bolts doesn't make a difference, they are there for nothing cause beneath there is still the alu cage without wholes or clips or whatsoever to remove it...
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Getting Paranoid!!
    i would give Jason @ JHM a call. Im sure he'll help you out he's a good guy
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Ohhh you must have a pre 2000 MY S4. I'm sure Jay can help you out, he is really a nice guy. About the customs fee, you might have to bite the bullet there
    If you can't find anybody to take it from your hands, let me know
    Feb 20 2008
    belgium
    yeah I know, but I wanted to know if someone could help me out or has ather opinions , I'm not pointing fingers @ jason cause he could not know this !
    it's just depressing after waiting 3 weeks + all this shit with customs I finally got the thing and I cannot even undo my stock shifter, as you see in pics something doesn't seem right...
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    i got to mine using this tool. idk if that helps.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    looks exactly how my a4 shifter was before i replaced mine. i believe that the part around the shifter is part of the body. when i swapped my jhm shifter i already had the middle console out due to other things going in as well.
    those 2 bolts closer to the ebrake handle and 1 other bolt that is under the console more towards the ashtray will losen the entire shifter thing so you can take it out. thats how it worked for me anyways. yours looks exactly the same though, so it still should be doable.
    wish i would have taken picture to help you out more.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Feb 20 2008
    belgium
    the problem is the metal/alu cage, I have all the tools but there is a cage without screws/bolts/clips whatsoever surrounding the whole shifter stuff!
    the bolts you see do not undo this, I screwed loose everything I could get to but the cage is still there , it almost looks like it is screwed from underneath , like you need to pull the trans to get to the shifter, weird but this is what it looks like.
    also the plastic opening is wayyyy smaller then you guys s4's , even smaller then the A4 B5 in the video on JHM racing!
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    That is why I sold you the new plastic center base from the newer models (00-02). Everything is fine.
    You need to undo the 4 10mm nuts that hold the box in. Then the box will be low enough to undo the 4 allen bolts. Then put the new shifter in with the new plastic B5 S4 base I supplied you.
    That simple man.
    Your car is just like the pre 99.5 A4s out here that I sell the updated bases to as well. They are not as roomy and are definitely harder to do, but I gave you all the parts you need. Unfortunately the pre 2000 center consoles just suck.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    no no im saying there is another bolt to loosen it closer to the ashtray. my console was removed, so i didnt think it was a problem when i installed mine. once you loosen those 3 bolts the shifter will drop providing more room to loosen bolts.
    my entire shifter and shifter area looked exactly like yours though. that aluminum cage you see is the opening in the body down the transmission. there is another more bowl shaped one on the under side that drops with those three bolts. once you get those 3 bolts, you will be able to loosen everything else.
    edit: i said 3 bolts, but Jay is correct and its 4.
    Feb 20 2008
    belgium
    ok, workin on it now! i'll let you guys know! thanks !!!
    Apr 27 2008
    Wittering, england
    I managed it on my 1998 S4, it was a bit bloody fiddley, but it's do-able. Think you need to undo the 2 bolts directly behind and in front of shifter, larger one at the front, smaller at the back, then the 2 bolts lower down towards the front, that hold the linkage to the shifter. Then the whole lot lifts out. The 2 brass bars stay in the car. Just take note where they all are to start with, there's massive amounts of adjustments, I couldn't select reverse the 1st few times I bolted it back together!
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    yeah, make sure you can get it in all gears. you most likely will have to adjust it. i had to adjust 2 times because i couldnt get reverse at first, but once i get that right i coudlnt get it into 1st. so be sure to check and amke sure you can get the gears.
    Feb 20 2008
    belgium
    FINALLY!
    damn what a job, but it's in there and shifting!
    first impression:
    - feels good , all gears are in place also reverse, but it feels a little notchy but it's new and I just put a little more grease on it + it could maybe use a little more adjusting but that's for tomorrow...
    - the shifter does not jurk around anymore, before when I got on it it shuddered and stuff but now it's nice and firm without any play!
    I'm happy, thanks guys and THANKS JASON @ JHM!
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by Audi_S4 View Post
    FINALLY!
    first impression:
    Your welcome man. Glad you enjoy it. When you shorten the throw you will feel the detents in the tranny even more. So if you don't get used to it, just move the lower bolt at the bottom of the shifter up to the top set of holes. This will lessen the reduction and give you better leverage to shift smoother, but with a little bit longer throw than it has now.
    Feb 20 2008
    belgium
    Quote Originally Posted by jaybquick@JHM View Post
    okay man, But I think I will let it sit back there for a while, it's been a long fight against all the bolts
    it feels good like this, I now finally know what it feels like to have a JHM shifter in the car!
    thanks!
    Aug 24 2005
    Lathrop, CA
    thanks!
    Did you get my email?
    Feb 20 2008
    belgium
    yup I got it!
