Results 1 to 6 of 6
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    S-line suspension 2008 Avant
    OEM S-line suspension (struts and springs) off a 2008 2.0T Avant Quattro
    Only driven about 4k miles! $400 shipped!
    Registered Member Two Rings
    May 19 2008
    PA
    Re: S-line suspension 2008 Avant
    Pm Sent!
    Mar 12 2008
    New York
    Nice allmine, get on that deal
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    these fit a sedan?
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    Only if its a quattro sedan.
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
    Feb 12 2004
    PA-NJ
    That is correct!
