Results 1 to 13 of 13
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    oil in engine bay...
    found some oil around the oil cap and all under my engine cover. Can any one point out what wrong with my car ?
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    Re: oil in engine bay...
    PCV! dealer
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    the infamous pcv im betting
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Jan 06 2008
    Dacia Sandero
    Arizona
    Another PCV bites it.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Aug 31 2007
    Miami
    is it covered under warranty? even with all the mods?
    IG | @fukn_fafa
    Jan 06 2008
    Dacia Sandero
    Arizona
    Covered under warranty, it depends on the dealership whether they're "mod friendly."
    Either way, its a known problem (just had mine done last month), and they'd have to be jerks to say your mods some how caused it, and they'd have to prove they did anyways, which they cant.
    Aug 31 2007
    Miami
    is there any upgrade for this shit, rather fix it once and be done with it
    IG | @fukn_fafa
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    ^ Yes, go to your dealer and get that PCV fixed. There should be an updated version that doesn't allow the same problem to occur again.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Registered Member Two Rings A4 S-Line's Avatar
    Dec 26 2005
    North America
    Quote Originally Posted by Ih8OEM View Post
    You can buy updated parts from ECS or whatever and DIY. I went out of my way to find a dealer that I knew would be mod-friendly (APR+TP). I got a couple scratches in my fender for my trouble, but it didn't cost me cash.
    ~Karl
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    get the eurojet pcv valve fix. It was designed for the MkV GTI which is the same engine as our with respects to the PCV. You can install it on our engines no problem, i did mine not to long ago because there was some oil in my pcv so before it got out of hand i swapped it out. its only 79 dollars!
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Established Member Two Rings fD3S's Avatar
    Dec 08 2006
    3rd Gen Mazda RX-7 tt / 07 A4 2.0T 6MT
    SouthFlorida
    07 A4 2.0T 6MT Quattro - APR 93/100 - Stasis coilovers - Ecode TP
    93 Mazda RX-7 tt Petit ECU, Down pipe, Catback, ACT clutch, HKS bov, K&N filters; Tein lowering springs, 99 Front end
    04 Suzuki GSX-R600 Yoshimura pipe; K&N filter; Vortex Sprocket; HID conversion; Hotbodies undertail
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    PVC! Its all over the forum. look at the stick on common problems. good luck with getting the stealership to fix it. dont remove the oil or clean it or anything. it is the sign they use to detect if you have a problem.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Another vote for PCV. The car is going in tomorrow for PCV and service (fist time since I bought it). I'll let you know if I get any negative comments on the mods.
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
