Results 1 to 8 of 8
    Registered Member Two Rings TripnA4's Avatar
    May 12 2008
    Dallas, TX
    Do you guys think 2004 1.8T is more reliable than 2002/2003 models?
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Re: Do you guys think 2004 1.8T is more reliable than 2002/2003 models?
    never had any recalls or major items with mine - that wasn't due to modding
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Jan 10 2007
    VA
    i would say the earlier model years tend to have more reliability issues. however the 02-03s are older and have had more time for things to go wrong. one thing i find troublesome about those reports is the B5 S4 seems to have a flawless record [O_O]
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    Comments
    Engine
    Significant Problems
    Occasional problems on this vehicle (1.8L Turbo only), are the failure of the Timing Chain Tensioner, the Oil Pump Pickup Tube, the Ignition Coil and the Water Pump and a periodic problem is a failure of the Catalytic Converters (3.0L only). Problems with the Timing Chain Tensioner may cause further engine damage that will increase the cost of repair. Problems with the Timing Chain Tensioner can prevent the engine from starting. Problems with the Ignition Coils are identified in TSB #010301. The cost to repair the Timing Chain Tensioner is estimated at $500.00 for parts and $195.00 for labor. The cost to repair the Oil Pump Pickup Tube is estimated at $200.00 for parts and $385.00 for labor. The cost to repair the Ignition Coils is estimated at $23.00 for each coil and $65,00 for labor. The cost to repair the Water Pump is estimated at $69.00 for parts and $260.00 for labor. The cost to repair the Catalytic Converters is estimated at $2000.00 for parts and $383.50 for labor. All prices are estimates based on $65,00 per flat rate hour and do not include diagnostic time or any applicable sales tax.
    Oh no!!!
    I just got CEL code P0431/P0421 from my 3.0 Quattro meaning both my cats are out last week!!
    Feb 07 2006
    ouellette
    Quote Originally Posted by b6onboost View Post
    however the 02-03s are older and have had more time for things to go wrong [O_O]
    you hit the nail on the head there.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    The oil pump pickup tube problem is a result of dirty oil or engine sludge. The pickup tube can be cleaned of the deposits with any acid cleaner and reinstalled there after. They cost of install on this piece takes more than just dropping the oil pan since the subframe will most likely need to be dropped to get it to clear for removal. Timing chain tensioners are the same part across the B6 board so it's really just time and miles (older the model gets) that make those things fail. The coil packs in all B6's just need to be "R" versions at this point. I do not like the oem B6 water pumps since they use plastic impellers. You can get older 1.8T model ones that have metal impellers. They will last much longer.
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    The 02's have fewer audi recognized problems. No recall for us on fuel pump. That aside, recalls and tech bulletins are pretty much identical from what I have seen.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    02-03 < 04-05
    Previous
    USP B6 A4
