Results 1 to 18 of 18
    Registered Member Two Rings
    May 19 2008
    PA
    Cracking sound over bumps...
    OK, I have 20,000 miles on my car and when I go over even small bumps I hear a cracking sound almost coming from the middle of my back passenger door on the drivers side. I'm going to take the wheel off and look around but its not all the time. Any ideas? I was goinig to switch the front and back tire to see if the problem follows the tire or not, hoping something isn't wrong with my rim but kind of figuring if it was the rim the craking would be alot louder or something else would have happened by now. So after that if the sound is still there I'll be off to the stealership (under warranty) thank god but any ideas? Thanks
    Veteran Member Four Rings swoardrider's Avatar
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Re: Cracking sound over bumps...
    Quote Originally Posted by Allmine View Post
    I have the same exact noise in the same exact location. Dealer has taken apart the interior b pillar to try and fix it with no luck. It's really F*^king annoying!
    '06 2.0T S-line Tip
    Stasis/Ohlins Motorsports, Stasis 14.5" BBk, Stasis rear BBK, H-sport rear sway, JHM 2+ tune, JHM 4:1 center diff, 18" Wed'sSports w/ 255/30 Toyo R888 (track), 19" Tenzo-R's w/ 255/35 (street), Stern upper arms, upgraded stereo, Huper tint, RS4 grill, JHM HFC, JHM downpipes,OEM S4 exhaust, track goodies
    May 19 2008
    PA
    Well, I switched tires last night and the F'in noise is still there... not all the time but I feel like my frame is cracked or something. I'm going to put a different suspension on my car and figured I would have them look around then but you are correct! It is VERY annoying especially when you know its there!!!!! I'll let you know if I find anything out. Please do the same for me. Thanks!
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    subframe?
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    May 19 2008
    PA
    Not sure, Its not always there and it can be when going over small bumps ( like a manhole cover) but on the highway going 75, going over a small (same kind of) bump nothing... not sure... but annoying!
    Nov 05 2007
    Naples, FL
    I don't know if it's the same sound, but sometimes, going over a speed bump, I'll hear a cracking, or more of a creaking. I think it's the plastic components in the interior of the car shifting as the frame flexes a little going over a bump.
    2012 Monsoon Grey A4 2.0, Convenience Package, Style Package
    30% Front, 15% rear
    Senior Member Three Rings Grassmonkey's Avatar
    Sep 23 2006
    B7 A4 DTM
    The Netherlands
    Yep Im a member of the same club.
    Although I think its at the top of the pillars behind the front seats.
    Dealer has tried several times to fix it no aveil.
    And since a couple of weeks now my center armrest is creeking during cornering...
    2006 B7 A4 DTM
    Mods: RS4 Pedals, RS4 side mirrors, RS4 grill, S4 Blades, PSS9's, RS4 rear swaybar, 034 HFC, Milltek Exhaust, ATP GT28RS, S3 Injectors, HPFP, Rennworx RSL 19x9
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Quote Originally Posted by Grassmonkey View Post
    I am a member of this club as well, although I'm not sure where it's coming from in my car. Sound like it comes more from my front A-Pillar, but cars are hard to find noises in sometimes. Something could sound like it's in front of you when it's in fact behind you. Nonetheless, I'm in this club as well.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    May 19 2008
    PA
    You know I have to say this club sucks! My noise I feel just started happening and I have only 20,000 miles on my car. I always felt like my car was a solid car but with some of the noises it makes...I don't know.... Well Like I said hopefully next week I will be putting on a different suspension and will be taking a closer look then so I will update this next week. Thanks
    Veteran Member Three Rings Silververtu's Avatar
    Sep 26 2005
    DMV
    It means time for a new car!!
    Current:
    2019 Porsche Cayenne Turbo
    Gone but not forgotten:
    2006 2.0T A4 Avant 2007 BMW Z4 Roadster 3.0si 2006 BMW M Roadster 2013 BMW 550i M Sport 2015 Porsche Cayman S 2015 BMW X5 50i M Sport
    Mar 12 2008
    New York
    I have the same noise, mine is coming from the B-pillar. I had the same on my B5 S4. It almost sounds like my car is flexing and the door is moving. It's weird but I'm chalking it up to another "audi" issue you learn to love
    Jun 05 2007
    Syracuse, NY
    OP: Are you sure this noise is coming from the exterior?
    I had the A/B pillar cracking also....I was able to largely eliminate it by loosening the bolts which secure the handles above each door...give it a shot.
    New Member Two Rings M Style S's Avatar
    May 14 2008
    2008 A4 S-Line/Titanium
    Pasadena
    Hmm..And seems to me that everyone who has this problem has an 06'?
    May 19 2008
    PA
    I have an 07' 20,000 miles and I really do not remember it making noise for the first 15,000 so..... I guess I can only have an audi for 15,000 miles then time to get a new one!!! YA RIGHT!!!!!
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Seems like some of us in this thread have aftermarket stiffer suspensions. My dealer is telling me that my noise is due to the car flexing from the stiff race suspension. My car was sent up to Stasis and modded when it was new so I never drove it with the stock suspension for a reference.
    How many of you guys in this thread have stock suspension and this noise?
    Anyone switched to aftermarket stiffer suspension and then the noise started?
    It's really annoying and I'd love to help myself and the rest of us get rid of it. It's inexcusable for a $40k German made car.
    '06 2.0T S-line Tip
    May 14 2008
    Pasadena
    Just because its German doesn't mean they wont have ANY problems...
    Mar 05 2007
    San Antonio, Tx
    Quote Originally Posted by swoardrider View Post
    This is what I chalk mine up to.
    Sep 23 2006
    B7 A4 DTM
    The Netherlands
    Its the flexing of the car, it started happening to me when they redid my street and made angled speedbumps.
    Yes an aftermarket suspension will contribute but even after while on a stock suspension it will start making noise.
    I'll try loosening the bolts.
    Oh and my Recaro's are now also making noise!!! :(
    2006 B7 A4 DTM
