Results 1 to 13 of 13
    Senior Member Three Rings SportSter's Avatar
    Jan 28 2008
    Silverado 2500 TD 2005 Audi A4
    San Diego
    FUDG I put in the wrong oil: Please ADVISE
    Okay so i went to my local motul dealer to get my oil changed im at 36k (last change was at 32k) They asked me what grade it took and i told them I didnt know, supposedly they looked it up and told me oh its just regular 5w30 synthetic.....
    So i get home and got the wild hair to "double check this." Every thing I have read on the forum says to use ow30 or 5w40!!! But then I got to my manual and it says to use 0w30 or that I can substitute with 5w30 or 5w40.
    They filled her up with about 4.5L of 8100 Eco-energy Motul sae 5w30 100% synthetic.
    Do I need to go get anouther oil change? Please tell me this will hold me for 5k miles.
    2005 Audi A4 1.8t Quattro 6spd
    Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
    1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
    Established Member Two Rings JohnnyG's Avatar
    May 03 2008
    too many....my audi: a4 b8.5 project
    LongIsland, NY
    Re: FUDG I put in the wrong oil: Please ADVISE
    you will be fine
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Should be fine.....
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    youre fine...ive used mobile 1 5w30 in a pinch.
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Dec 19 2007
    York, PA
    youll be fine, now you can sleep
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I dont see the problem?
    The manual even says you can use 5w30....
    0w30 and 5w30 oils have the same viscosity....it is just their working temperatures (what they can withstand) are different
    -Sami-
    Jan 28 2008
    San Diego
    0w30 has I higher temp range?
    actually, thx i did stay up to atleast see several posts.
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    w40 is better at high temp like when it pass in the turbo...
    Senior Member Two Rings akordboy's Avatar
    Feb 24 2008
    B6 A4 1.8tQ 6-sp
    York, Pa
    They don't have the same viscosity. At 30°, the 5W30 oil acts like 5 weight, where the 0 is less viscous (hence 0W) at 30°. If you are in SoCal, where it is hot as right now, a 5W30 is thicker than 5W40 because it stays more viscous to a lower temp. That all being said, you're not going to do any damage using any of these oils unless you are driving the car like a raped ape all the time, then you might want a 5W-20. Fuel mileage may be marginally higher under normal driving conditions with a lighter weight oil like 5W40 because of less friction in the rotational parts.
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 09 2004
    east bay, CA
    you're just fine!
    and to make yourself feel better, you can top off with 5-40 (if you burn a little oil) I would use the same brand/line of oil to do this.
    if you drive normal, then no worries at all. if you drive REALLY hard, then maybe drain out 1 liter, and put in 1 liter of 5-40 now. but honestly, my guess is that you can do at least 1-2K before this oil thins out to any degree.
    - Benny
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    your engine's gonna melt!!!! j/k, your fine.
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    that oil is fine dude... motul is good shit
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    the book says 5w 30 so I think your fine. That's what I use.
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
