Results 1 to 10 of 10
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Passed Smog Check with test pipe
    Just like the title says passed my NV smog check with a test pipe and Revo Stage 2 K04. They just plugged it in to the ODB II and let it do its thing and it passed. I've been dreading this day since I installed the test pipe a year ago and was happy to see this result. I just thought others in the same situation would like to know.
    ...I didn't even have to slip the guy some extra $$$!
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Dec 06 2007
    Re: Passed Smog Check with test pipe
    nice
    -Kirk
    BetaAlphaTau Member #58
    Marin, Ca
    Damn, I failed NV smog on my Avant last month. Do you have your I/M readiness print out around?
    -Tony
    '68 Datsun 520
    '71 2002 Tii
    '22 Mercedes-Benz Sprinter
    '22 RS6 Avant
    '20 L405 RR P525
    Jun 30 2007
    Raleigh, NC
    i thought for smog testing they hooked you up to a sniffer?
    as far as normal OBD-II inspection stuff goes, I passed with a test pipe and no aftermarket software. I just unplugged my battery for a few seconds to reset everything right before i went to the inspection station
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Certain states and/or counties do sniffer tests, some don't. And it tends to depend on the place you get it done, too. I passed a sniffer test with a HFC, no problems, and you're not even supposed to be able to do that around here.
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Quote Originally Posted by B6Lovin View Post
    Disconnecting the battery will reset all your Readiness Codes which in most states that perform OBDII testing would mean automatic failure. Not sure what the law is NC.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by skeeball View Post
    Yeah, should throw a code stating the battery has been disconnected in the last 80 miles or 5 starts (something like that)
    Cali seems to be the worst with emissions. Back in IL, they just plug into your obdII and just go with that info. My buddy had a dsm with a 60trim, test pipe, external wg vented to the atmosphere, an exhaust leak at the manifold-turbo gasket, & some big cams... Dsmlink has a fun little option that lets you ignore certain codes... it passed obdII check without a hitch... even if it is burning a hole in the O3 wherever it goes...
    Then I look at the haze overlooking socal and think... catayltic converters aren't so bad...
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    i dont think the sniffer can be used unless they have a treadmill that can be used for awd cars?
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    May 14 2008
    W-S, NC
    Quote Originally Posted by diztek View Post
    Very good point, because I know there is some specifics on engine temperature and load bearing when they run the sniffer test.
    Jun 30 2007
    Raleigh, NC
    doesnt matter for me anyways - time to break the mold :)
    im going unitronic monday/wed (depending on shipping times to/from canada) i'll make a new thread with results and impressions
    and it doesn't matter because the tuning bypasses all of the usual problems :) not just cat-deficiency checks.
    The Awesome™
