Results 1 to 26 of 26
    Oct 25 2006
    oregon
    Boost Controller
    Ordered a MBC off ebay and installed it today. Wouldn't limit boost no matter where I set it. I'd keep hitting 25 PSI. I have the waste gate T'ed off going to the N75, and the Turbo outlet T'ed off going to the n75. The APR Inlet is going to the longest nozzle on the N75.
    I'm assuming it's some shitty product considering what I paid for it.
    Now I'm looking at EBC's. Anyone have any advice on a simple one with just one boost setting, easy to install, etc?
    Saw a Blitz dual SBC one I was thinking about and a greddy PRofec. Gizzmo has seemed the easiest so far.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Re: Boost Controller
    Apexi AVC-r FTMFW
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Oct 25 2006
    oregon
    Quote Originally Posted by gotaudi View Post
    Apexi AVC-r FTMFW
    Reading through threads I heard it's over kill.
    If the MBC had a shitty spring I'm still assuming it would be able to limit the boost some amount, correct?
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    Here ya go, this is what everybody uses on here!
    http://www.3barracing.com/product_7.htm
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by slopoke View Post
    No body here uses that. That thing is made with Home Depot parts.
    If I was to buy a new EBC I would go with the PBC-1 from World Motorsports. I use been using a HKS EVC 4 since 2001.
    Oricle - did you try hooking the pressure hose from the turbo directly to the wg actuator? It could be that your WG is stuck shut causing the turbo to hit 25psi no matter what and I would check to make sure that the wg is working correctly before you buy a EBC.
    Aug 16 2007
    Buffalo NY
    http://www.3barracing.com/product_6.htm thats one even better, thought i have seen atleast 20 people in the b5 threads using these, and they all love them... Also they were formerly Dawes racing which is the name i have seen alot in here.
    Jul 07 2004
    socal
    I dont know anyone that runs that junk. The # 1 MBC used world wide is the Hallman MBC.
    or their Pro MBC
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    The harder I practice, the luckier I get.
    - Gary Player
    Aug 16 2007
    Buffalo NY
    i have seen Dawes mbc in alot of peoples sig's, but those ones do look a hell of alot nicer.
    Aug 16 2007
    Buffalo NY
    Wow those are cheap for the quality $70
    Oct 25 2006
    oregon
    Thank you. I'll try it out.
    Just hooked it up. 4th gear it wouldn't get past 15 PSI, 3rd gear I spiked at 18 and it dropped to 14-15 PSI.
    Oct 25 2006
    oregon
    I'm assuming boosting to 15 PSI means the WG isn't stuck shut, meaning I just have shitty luck with boost controllers?
    Dec 07 2004
    Quote Originally Posted by Oricle View Post
    or maybe the n75 is still controlling boost somehow.
    - Gary Player
    Jul 07 2004
    socal
    Well the WG is working, just means it has a 15psi spring. Did you try using just the MBC with the N75 just looped between the 2 nipples and the harness plugged in?
    Oct 25 2006
    oregon
    http://ctny.audiworld.com/mark/s4/mi...c_parallel.jpg
    Used this diagram to hook everything up. Should I try eliminating the N75?
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    you should use a bleed type instead of ball and spring
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Oct 25 2006
    oregon
    Quote Originally Posted by maxspeed View Post
    I'll order one right now.
    Thank you.
    Never talked to anyone running a bleed style. Should I go for a hallman MBC?
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    whats your deal? all of the comments you make are fucking stupid...especially this one, i've never seen anyone on AZ using those shitty MBC's you posted what do you work for them or something?
    Dec 14 2006
    Halifax, NS, Canada
    looks like something for a garden hose
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Jan 26 2006
    2001 A4 1.8T
    Socal
    I like it because you can tune it to your hearts desire. Complex is the wrong word to use, I would classify it as complete. It can do almost everything you would want a boost controller to do. I am really happy with mine and I got it for $200 so that made it even better.
    Mods:
    Aug 16 2007
    Buffalo NY
    Quote Originally Posted by AudiRacerS4 View Post
    Lol no guess i have seen him(bass lover1) post alot about this sorry, the ones you posted do look much nicer and seen they are only about $70 thank you, glad i didnt buy one of these dawes things yet, i thought they looked like garbage too.
    bass lover1
    98 1.8TM Royal Green Passat - Evoms CAI w/ Custom Heat Shield - Hyperboost DV - Custom Magnaflow exhaust - Dawes Hybrid MBC @ 11psi - 4 point upper strut bar - Chas Lower Tie Bar - APR Snub Mount
    Oct 25 2006
    oregon
    I ended up putting the MBC on standalone. Kept my N75 plugged in with the APT inlet's line running to it and capped off the other ports on the n75.
    I'm boosting to 15 PSI and holding no matter what setting on the Ebay MBC. Figuring the thing is screwed. Ordered a Hallman MBC like Mike suggested. Hoping this shit gets fixed soon. Once I reclamp my MAP I'm going to end up redynoing and see what numbers I can get.
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Slopoke you're from AF aren't you...
    That explains it!
    Aug 16 2007
    Buffalo NY
    Af?
    Established Member Two Rings EOD-5's Avatar
    Apr 20 2008
    98 A4 1.8tQ, 1990 Miata
    Newark, Delaware
    Af?
    audiforum...just stop talking bro....you dig yourself a hole every time you type a word
    1998 Audi A4 1.8tQ 5 Speed
    VVME 4300k, RS4 Grille, GIAC, Piper Cams, APR TIP, Blinktek Heatshield, Forge FMIC, Catch Can, TurboXS BOV, PowerGasket, ECS FP Gauge, VDO Boost Gauge, ATE Slotted Rotors, PBR Pads, RubberTite Floor Mats, 034 Coil Cover
    1990 Mazda Miata
    not stock
    Registered Member Two Rings
    Mar 23 2008
    seattle
    this is what my friend it running on his 1.8t w/ a Greddy profec B, and it works great
