Results 1 to 20 of 20
    Oct 10 2007
    B6 1.8T USP
    Vibration from Engine
    I have B6 1.8T Tip.
    When the car is idle, I can feel some vibration. Especially when it is cold out there, it gets worse. A few months ago, if it was warm, about 65+, I was not able to feel the vibration. However, now I can feel it even if it is like 70s.
    I still have the warranty and I do have the extended warranty, so I tried to fix it at the dealer. I thought it is a engine mount problem, but the dealer told me they cannot feel anything from the car. Yes, I can be sensitive, but it is getting worse.
    Can anyone give me an advice? what do i have to do? lol
    With Vag-com, there isn't any false code.
    I really want to fix it.
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    Re: Vibration from Engine
    I have the same problem - its common with tip A4's apparently - do a search
    isnt somethign dealers can fix *shrug* - thats just the way t is
    i just put it into neutral these days
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Oct 10 2007
    B6 1.8T USP
    Just wondering. Is this common with any automatic? or is this just Audi?
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    You're not alone. My car does the same thing. I've been on other Audi forums and have heard of the same problem and no solution. I don't know why, but if this is "how they're made" Audi should have had some solution to it to back up they're luxury image...imo. Let me know if u happen to find an answer to this cause I sure have tried and failed...
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Oct 10 2007
    B6 1.8T USP
    Quote Originally Posted by jonsaudi View Post
    That is what I am saying. I'm not driving Kia, and the car gets like this in 3~4 years. I used to have Passat 1.8T before A4, and it did the same thing. I bought the passat as used one so I though the previous owner treated the car suck. After driving A4 for a while, same problem kicked up, and search tool confirmed that many people face the same problem. What about other Audi's? 3.0 engines? A6s, TTs? Do they do the same thing after a few years? Wonder whether MB and BMW do the same thing after a few years.
    it is just annoying
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Did you check the engine/tranny mounts. Maybe one of them has failed. Also, if you have a slight vacuum leak, that will cause it too.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    engine/tranny/ snub mount?did you get under the car and take a look?
    engine mounts leak when they are bad, snub usualy crack. tranny you cant tell. but its good to replace them
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Three Rings Rons01B5's Avatar
    Oct 17 2005
    Long Island, NY
    Vibration at idle is normal for a4's. Both my B5 and B6 had it. The idle speed is set by the manufacture for emissions reasons.
    2012 A5 2.0T QUATTRO 6-SPEED
    GIAC Stage 1---R8 Coilpacks---H&R Coilovers---S5 Speedline Wheels---H&R 20mm Spacers---Ecode Alu Kruez---H&R Sway Bars---034 Trans Insert---P3 Cars Gauge---JHM Shifter---GFB DV+--S-Line Front Bumper---Black Optics Grille
    2003 Amulet Red Audi A4 1.8TQ 5-Speed - SOLD
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    mine started doing that this winter too. Changed snub and motor mounts, but it still does it.
    Sep 02 2005
    Montreal
    Yeah, it's normal.
    Jan 11 2011
    Las Vegas, NV southwest
    lets all get together and write audi a mass letter and demand they put their heads together and figure his problem out. Iam sure on highly trained Audi tech can solve this vibration issue by why when it cost plenty of $$$$ to fix this issue. we will pay it because we love our audi's, oh yeah my car vibrate's too.
    Active Member One Ring grafteq's Avatar
    Jan 09 2011
    2004 A4 1.8TQ 6MT USP
    Hartford, CT
    Can't you use the VAG-COM to set the idle speed a little higher? I seem to remeber reading that somewhere here on AZ. My 1.8T vibrates at idle as well, but once i bump it up even a few rpms with the throttle, it smooths right out.
    Established Member Two Rings Zaloo's Avatar
    Nov 02 2009
    Lexington KY
    Quote Originally Posted by grafteq View Post
    I was going to try this week - any DIY or anyone know where to go on VAGCOM to set the idle speed?
    2005 Audi A4 1.8TQ Tiptronic, APR Stage 2+ w/ shit tons of mods. AZ wouldn't let me list everything...
    Deactivated Three Rings
    Nov 28 2009
    taxachusetts
    what is the idle speed on a TIP?
    Veteran Member Three Rings zamflip's Avatar
    Sep 21 2010
    Bayliner 175, 2014 JGC wk2, and wifey s40
    Smithfield, ri
    Yeah, count me in too... I hate that vibration feeling! while i drove my gf's 07 s40... felt like so 300k dollar car! smooooooth! but, i still always love my audi and how its look right now... cant get sick of b6. So, i will just buy myself some snub mounts and see what happens later on.
    Feb 10 2009
    03 Moro blue A4 Avant 1.8T/Q
    Sherwood park,AB
    I moved my idle speed via vagcom by about 30 rpm's lower and changed the front snub with an apikol one, i did this in the summer and there was little to none vibration, now that it's cold out it vibrates like a mutha. I think it has to do with temp also.
    Jan 11 2011
    Iam a newbie.. what is VAG-COM? how can i get ahold of it?
    Established Member Two Rings swiderek's Avatar
    Jan 10 2011
    Oak Lawn, IL
    As I work for a dealer. Past 3 years almost every single A4 1.8 we had with automatic transmission had that problem. Currently we have 2 that are with manual transmission and they have zero to very little vibrations. Tested cars ( by me ) had between 25,000 to 80,000 miles.
    My '03 1.8 also have that problem and mechanic told me that he "thinks" engine mounts are bad but they look fine from the outside.
    I can have both for $100 and will replace them by myself when it gets warmer. Will see if that's the problem.
    Sep 02 2005
    Montreal
    Quote Originally Posted by grllanaudi View Post
    Seriously? http://lmgtfy.com/?q=vag-com
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    Quote Originally Posted by swiderek View Post
    if you do A6 engine mounts then they are about 26 dollars a piece.
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
