Results 1 to 21 of 21
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    ATTN:REVO 550cc injector file owners with SAI pump removed
    It has just occurred to me that I don't get a CEL for incorrect secondary air pump flow anymore ever since I got flashed with the 550cc file.
    Have you noticed too?
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: ATTN:REVO 550cc injector file owners with SAI pump removed
    Not to jack your thread, but on another note:
    I have the 8500rpm file and the 8500 file is only tuned for 550cc injectors and 3" maf housing with 1.8 sensor as per a phone call with revo usa this morning. That means there is no 440 file that runs to 8500rpms. They told me that I should not be getting a "MAF upper limited exceeded intermittent" code with this file since that code should be blocked/turned off. Shawn, do you have the 8500 file as well?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    No Shawn doesn't. Jordan you've got PM.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    are you serious?
    that is effing awesome!!!!
    no i can pass emissions worry free..
    gotta find me some 550's now
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jun 30 2007
    Raleigh, NC
    not to crap on revo (george is the man and the software is amazing!) but there's a few other options out there -- one of which disables all readiness checks so you always pass.. no matter what.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Sep 17 2006
    SLC, UT
    ^much cheaper to upgrade for free. then it is to pay $900 for new software..
    but one day......
    Current:
    Previous:
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by CO AVANT View Post
    Isn't that file also able to run "mafless"?
    Mar 21 2006
    Lakeland, FL.
    Revo BT can be used without a MAF.
    I'm back bitches!
    Feb 12 2004
    Everywhere
    I don't mind getting the Maf code, but was told it should have been "turned off" in the tune by the guys at Revo usa yesterday... just kind of wondering what was up with that.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Assuming that is the file you have..... How can you verify?
    -Doug
    Feb 12 2004
    Everywhere
    Robin@Revo told me on the phone that the 8500rpm file is only tuned for 550's...not 440's
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I meant, how can you verify that you truely have the 8500 file on your ECU?
    -Doug
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    step on the gas and if you go 1" above red line you're good to go....
    APR Tuned Serbia
    Authorized APR Distributor
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by zemun2 View Post
    bwaHAHAHA! i wanted to post the answer to that
    Current:
    Previous:
    Feb 12 2004
    Everywhere
    hahaha, good one Dejan... Doug, I got the file after a couple hundred miles into my last build. Blew the rod bearing about 10 miles down the road after I was rev'n to ~8100rpms.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    I had my guys ask REVO if they have a 8500 file and they were told it doesn't exist.
    So what is the deal here?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Jordan,
    I was just asked for I recalled you had some doubts as to what your ECU was flashed with.
    -Doug
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by [email protected] View Post
    Maybe it's not a file but they change the rev. limiter in the ECU. I sent mine directly to REVO for them to change.
    I'm back bitches!
    Sep 17 2006
    SLC, UT
    no one can sell it but Revo[directly. not some vendor/retailer] and Ecode, correct?
    Current:
    Previous:
    Jul 07 2004
    socal
    Quote Originally Posted by sean1.8t View Post
    Correct. Ecode is able to sell that file because they only offer the file to customers that they know to have a fully built head. Just cuts down the chance of the file ended up in some stock head car and the customer takes it to 8500.
    Feb 12 2004
    Everywhere
    Then why do I get a fault code for the MAF when Robin@Revo said that code should be blocked? He was supposed to respond to me and hasn't in the last couple days. Can the 440 file be tweaked to rev to 8500rpms or not? I know I shouldn't be getting this code with the 550 file after talking with REVO. Just trying to figure shit out. It faults at 10psi just the same as it would at 24psi... My max g/s readings are around 205 with the VR6 maf housing, 1.8t sensor and 550cc genesis.
