Results 1 to 34 of 34
Thread: She runs
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    She runs
    Well I was able to finish relocating the battery in the trunk, safety switch and running all the new wires.
    Bad thing is that my fuel return line is leaking now so I have to fix that before I can take the car out to the track again.
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Re: She runs
    fix it and hit the track already! you are such a slacker mike.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    Re: She runs
    sorry if this is a stupid question
    but whats that switch for
    battery cut off?
    Jul 07 2004
    socal
    Re: She runs
    Quote Originally Posted by dingguhlbary View Post
    battery cut off?
    Yes, it is meant to turn the car of completely if it is running. So it cuts the main 2 gauge battery cable and battery power to the 034 stand alone.
    Quote Originally Posted by Eurotuned_A4 View Post
    LOL, yeah the car now comes second to the kid so I can only work on it when I actually have time. New fuel line parts are on their way. I just have a few other things I need to do and the car is ready to go.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Re: She runs
    At this rate you are never going to get into the 9's like I hoped ... J/k it is a slow process and always the kid comes first... what is your next turbo choice? GT4088r?
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Oct 06 2004
    Minnesota
    Re: She runs
    Where are your subs?
    lol
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Jul 07 2004
    socal
    Re: She runs
    Quote Originally Posted by gotaudi View Post
    What ever Full-race throws on it.
    Most likely a S364 or the 4088r.
    Senior Member Three Rings Solaris's Avatar
    Feb 01 2006
    NC
    Re: She runs
    At what point are you required by NHRA rules to have the battery cut? Just curious, you couldn't fit it under the bumper so you could avoid drilling into the body?
    Jul 07 2004
    socal
    Re: She runs
    Quote Originally Posted by Solaris View Post
    When ever you relocate the battery to the trunk. I wanted the switch in the highest spot, actually mike at WMS had the switch located in the same spot but on the other side of the car. It isn't like I plan on selling the car any time soon since I will be putting a full cage by next month, I just need to pull the dash and strip the spots on the floor where the cage will be welded.
    Jan 26 2006
    2001 A4 1.8T
    Socal
    Re: She runs
    isn't it more of a safety issue than a rule?
    Mods:
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: She runs
    this threads worthless w/o vids
    Jul 07 2004
    socal
    Re: She runs
    Yes it is a rule and safety because it isn't like they can get into the trunk very easy if the battery is relocated. The switch also needs to be installed so that if the car is running it will cause the car to stop running when the switch is turned to the off position.
    Quote Originally Posted by 317ssayzarc View Post
    Well no reason for vids yet since I cant keep the car running because the fuel return line is leaking at the spot where the AN fitting is connected to it. Once I saw that I shut the car off and called Javad at 034, they built me a new line and shipped it out today. Once I get the new line installed, pull the old oil drain fitting at the pan so I can remove the old catch can and change the oil I will take some vids of the car running again.
    Good thing is that once I got it all wired up the car stared right up on the 2nd crank, shut it off for a few minutes and it started right up on the first crank. Now I just need to wire up the start button I installed.
    Registered Member Two Rings
    Aug 19 2007
    central oregon
    Re: She runs
    im gonna turn off ur car when i walk by all the time.
    then you can reset the clock, radio security code, and maybe other stuff that i dont know about. ya! take that!
    Jul 07 2004
    socal
    Re: She runs
    Quote Originally Posted by airy52 View Post
    Well seeing that I only use the car at the track I never look at the clock, there is no radio and I dont roll the windows down anyway. The switch will always be in the off position when ever I am not in the driverseat.
    Aug 16 2007
    Buffalo NY
    Re: She runs
    Maybe a dumb question why did you relocate the battery, its not like you need more wieght in the back since its our front tires that spin well atleast mine do, the back never do... Or did you just need more room in the bay? Also is this car awd or fwd?
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Re: She runs
    his car is quattro and his tires will spin a shit ton. 600whp tends to do that. where his battery was there is now a huge catch can, so maybe thats why it was relocated.
    Jul 07 2004
    socal
    Re: She runs
    Correct. I installed a custom OEM batter size catch can in the stock battery location.
    My car is quattro but I am still able to spin the drag radials pretty easy.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: She runs
    Love that quote.
    What is your car's race weight/corner weight? I gotta imagine that it's still nose heavy.
    Dec 14 2006
    Halifax, NS, Canada
    Re: She runs
    do you have a LSD mike?
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Re: She runs
    You should take that switch in the back and replace it with a FUNK button. I would laugh my a** off if you did.
    Jul 07 2004
    socal
    Re: She runs
    Quote Originally Posted by djwimbo View Post
    Love that quote.
    Have never put the car on corner scales, but the car still needs to be nose heavy other wise the front wheels will end up coming off the ground during a hard launch. The car should be under 2900 lbs, but I wont know till I put it on a scale again.
    Quote Originally Posted by Squarrl View Post
    Nope, drivline is 100% stock.
    Quote Originally Posted by VTAudiA4 View Post
    I will most likely remove the moroso sticker and just put ones that say on/off, maybe I will put FUNK above the switch just for the hell of it.
    Nov 06 2005
    Denver/Fort Worth
    Re: She runs
    have you thought about running a smaller battery? that thing still looks like it could lose some weight
    Jul 07 2004
    socal
    Re: She runs
    Quote Originally Posted by JeffM1587 View Post
    I had the PC680MJT but it died, the PC680's are back ordered nationwide and they have no idea when they will get more. So I went with the next size up which is the PC925 when they offered to replace the dead battery under warranty.
    PC925 is 24 lbs
    PC680MJT is 16 lbs
    Picture of my engine bay with the PC680MJT installed. I still have the billet battery holder for the PC680 if anyone wants it.
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Re: She runs
    That thing looks really slow.
    Definitely an embarrassment to AZ.
    Whats that stupid ricer switch on the trunk? Srsly. Worst place to put your neon controller.
    Stupid ricers these days.
    ÖMGHI2Ü
    Photography
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: She runs
    Garrett FTW!!
    And Hurry the fuck up Mike!
    Jul 07 2004
    socal
    Re: She runs
    Well the new braided fuel line showed up today. Took me 5 minutes to remove the old one, cut the stock line at the fender and install the new one. Car started right up and there are no fuel leaks. Just need to swap out the fuel return flange, change the oil and pull the old catch can out. Would have done that today but its raining and I haven't had a chance to pick up a new oil filter from Purems.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Re: She runs
    You're thinking of possibly straying from Garrett and going Borg Warner?
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    Re: She runs
    thats outstanding i wish my quattro would spin
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Re: She runs
    damn i need one of those coilpack covers in cf. that looks sick!
    Jul 07 2004
    socal
    Re: She runs
    Quote Originally Posted by bassed View Post
    Geoff at Full-race brought up the idea of trying a Borg Warner turbo on my car for a twin scroll setup since they seem to fill in the holes between the Garrett turbos. Only down side is that they are only oil cooled and I will be running at at very high boost, but since its for drag racing it might not be all that much of a problem.
    Let me know, I have plenty of them sitting on a self in my office.
    Still waiting for the dry carbon look pieces to show up. I can also have them made in Kevlar(any color).
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Re: She runs
    yeah im trying to save some cash atm. when im ready ill let you know though
    Dec 05 2006
    quebec/gatineau
    Re: She runs
    no one was running these turbos on VW/audi so we decided to try them out spread the info around, and glad that more cars are running them cuz they are awesome, you won't have issues with oil cool only at high boost these are made for that.
    good luck and watch your times get quicker..
    Sep 24 2005
    always in design
    Re: She runs
    Quote Originally Posted by autoxtrem View Post
    Right now it's just you and me running them I think, or well at least that I know of
    Jul 07 2004
    socal
    Re: She runs
    Well I hope my times get quicker going from a 65 lbs/min turbo to a 75 lbs/min turbo.
    I had one of the very first Airwerks(Borg Warner) S series turbo on my car way back in 2002-2003 when they first started doing some testing on that line.
