After installing downpipes, I got a whole mess of codes. Keep in mind that wires underneath had been rotted and touching but have been repaired now, although the damage has been done:
(The ones in bold are the codes I don't know how to fix. I just bought a new N75, N249, and MAF from ecs.)
16518 P0134 035
O2 Sensor Circuit, Bank1-Sensor1
No Activity Detected
16538 P0154 035
O2 Sensor Circuit, Bank2-Sensor1
^ These I can clear, I got them because I'm running no cats. Now, onto the others:
17833 P1425 035
Evaporative Emission (EVAP) Canister Purge Regulator Valve
Short-circuit to ground
17938 P1530 035
Intake camshaft control circuit
17955 P1547 035
Wastegate Bypass Regulator Valve -N75
^ Bought new N75 to fix this.
17697 P1289 035
Recirculating valve for turbocharger -N249
^ Bought new N249 to fix this.
17529 P1121 035
O2 Sensor Heater Circ.,Bank2-Sensor2
17525 P1117 035
O2 Sensor Heater Circ.,Bank1-Sensor2
17522 P1114 035
Bank 1, sensor 2
Internal Resistance too Large
17548 P1140 035
Bank 2, sensor 2
And finally, the one I think started it all and is putting me in limp mode:
16486 P0102 035
Mass Air Flow (MAF) Sensor -G70-
Signal too low
^ Bought a new MAF to replace this.
Did I make the right moves by buying these new parts? The wires that the shop found to be fucked were all fixed. I just don't want to install these new parts and have them short circuit again. Any good places to check for other bad wires?
