Results 1 to 22 of 22
    Veteran Member Four Rings KareemA4's Avatar
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Cold Air Intake In Miami??
    I was thinking about getting a Carbino Cold Air intake for my car.
    And my friend was telling me something about how in miami that its too hott and my engine will flood and will be destroyed an etc...
    Mabey he was just lieing.
    I dont know too much about the subject, so i thouhgt mabey you guys could help me out.
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    Re: Cold Air Intake In Miami??
    carbonio isnt gonna make it WORSE, that's for damn sure... u will get great sound, and propably no gain... I'd go with a boosted tech true cold air intake that goes all the way down, if I lived in Florida..
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by KareemA4 View Post
    I wouldnt in florida....
    Registered Member Three Rings Amze's Avatar
    Apr 10 2007
    2003 Audi A4 1.8TQM
    Phoenix, AZ
    lol.
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    I haven’t been able to get my head around this statement yet...
    Previous
    USP B6 A4
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    sry that i dont know that much......
    Mar 22 2004
    Castle Rock, CO
    Good, you should be embarrassed!
    I'm only kidding man, seriously though. If you're looking for a solution to obtaining cooler intake temps to avoid going into "Limp" mode, I would recommend you getting a True Heat shield from the AZ classifieds first. This segregates the ambient engine bay temps from your intake side. If that doesn't lower the temps to your liking (they'll be considerably lower regardless after the heat shield mod) then look into getting an alternative intake. Personally the OEM intake works just fine when complimented with the heat shield and Power gasket.
    Previous
    USP B6 A4
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    ^^ whats a power gasket?
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Mar 22 2004
    Castle Rock, CO
    Quote Originally Posted by mattman View Post
    It's an intake manifold gasket replacement.
    Taken from ECS's web site;
    Made from a high performance polymer Power Gasket™ conducts on average less than 1/500th of the heat of the steel gasket that it replaces. Your intake manifold will stay 30-50° F cooler and your incoming air will stay 20-30° F cooler.Power Gasket™ has been designed for affordability easy installation and no disruption to your manifold attachment and engine accessories. This means that you can simply swap your old intake manifold gasket for a Power Gasket. No buying longer bolts or installing multiple gaskets. In less than 2 hours you will be enjoying a more powerful better performing ride.NOTE: Does not fit Audi AEB Engines
    Previous
    USP B6 A4
    Dec 06 2007
    ^^never Heard Of That But Hey I Might Check It Out!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Thats BS I got a Cone filter with a heat shield and no matter what you have when it gets hot down here it gets hot even with my intercooler still in the days my car is way slower than in the nights.... If you do get it make sure you get a heat shield... Good Luck
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    IIRC, I think the "power gasket" is usually referred to as "phelonic spacer"
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    To the OP, if you are still running the stock SMIC then an upgraded intercooler is going to be a far better investment than an intake.
    May 03 2005
    Boston
    Quote Originally Posted by skeeball View Post
    2nd, especially in Miami.
    EPL S2 + TCU
    Previous Cars:
    Registered Member Four Rings A4 ABT's Avatar
    Feb 23 2004
    03 A4 1.8T Quattro
    Sunshine state
    I've been running a Carbonio intake in South Florida for the past 2 years with no issues at all. You might want to consider saving some $$ for an upgraded intercooler instead of an intake, it's very useful in summer!!
    '03 A4 1.8t Quattro
    Exterior:USP front w/ Kerscher splitter--ABT sides--Votex rear--S4 trunk spoiler--S4 Door Blades--Euro blindspot mirrors--19" ACE Klassik
    Brakes/Susp.:NS rear swaybar--Audi Sport Suspension--NS brakelines--ECS OEM 3.0L brakes--Hawk pads
    Engine:GIAC K04--Genesis 380cc injectors--Okada CP--AWE Tuning FMIC--APR stealth exhaust--ER Test Pipe--Carbonio V2--Forge Splitter--Forge TIP--NS snub mount--ECS Stage 3 Clutch
    Interior:AWE Tuning Boost Gauge
    Oct 23 2007
    Ontario, Canada
    thanks
    Quote Originally Posted by Gallep View Post
    It's an intake manifold replacement.
    Meet Shanice...
    For Sale:
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    Thank you for all the help guys
    Ill see what i will do
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    I remember someone here did a review on the gasket and the conclusion isnt that great at all. As for intake, just use stock box....
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Sep 02 2005
    Montreal
    Quote Originally Posted by initiala4 View Post
    I remember someone here did a review on the gasket and the conclusion isn’t that great at all.
    It moves injectors, affecting the spray pattern. Also, there is more than one temp. sensor, and the ECU calculates internal temperature based on the values these sensors provide, one being inside the manifold. With the gasket, the manifold sensor will screw up the results, and the ECU will assume the block is cooler than it really is. The potential harm being done by this gasket may not be apparent, but in the long term, it may accelerate engine wear.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    as for the phelonic spacers, i did a bit of research a while ago and came across a bit of info.
    apparently its good for intake temps and such, but its also bad because it keeps all that heat in the engine block rather than dispersing it through the manifold and such.
    don't really know how it effects anything. installed them on a friends tl type-s, and he said it made a difference while driving.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Saint Cloud, Fl
    you mos def want to buy a FMIC first
    instagram ------------> low_enforcement
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    wtf tell your freind hes an idiot. I dont get it, why does running a carbonio or cold air intake(another car) in Miami going to kill your car?
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
