Results 1 to 9 of 9
    Senior Member Two Rings 215 Motoring's Avatar
    Oct 13 2007
    01 S4 Stg3 Bound, 05 R1
    The 215 & 302
    ignition coil pack #4 not responding???
    im getting misfire here...
    im getting power and ground to the connecter that goes into the coil pack. getting power to the injectors.
    1)when i take coil pack #4 and move it to #1,2,3,5,6 (no response)??
    2)when i take working coil packs from 1,2,3,5,6 to # 4 location (no response)
    3)Switched POS without changing coil packs now #1 & #4 nothing??
    btw i replaced all spark plugs checked all injectors
    whats wrong with this picture?
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: ignition coil pack #4 not responding???
    This happened in my A4 1.8t. My ICM (Ignition Control Module) went out, and also messed up a coilpack.
    You now know that #4 coil pack is bad, and now none of your WORKING coil packs are operating in the #4 location. SO the ICM should be the problem.
    It looks like this:
    There are two on top of your air box. Maybe you can try swapping them and see if the misfire moves to a different location. If it does, then you know it's the ICM before you throw parts at it.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Dec 06 2007
    Calgary, AB, Canada
    Oct 31 2005
    Ashburn
    I to have had mulitply misfire on my car often, As the others stated above check your ICM, that was my culprit.
    - Instagram: @Sinister_rs5-
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by Elitedrumr View Post
    It looks like this:
    thanks for the info
    Oct 13 2007
    The 215 & 302
    Quote Originally Posted by The_Jerbel View Post
    thanks again Jerbel
    Oct 13 2007
    The 215 & 302
    i think the ICM are my problem!!! ordered two today should have it on friday. keep u guys posted... thanks for the help
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Quote Originally Posted by 215 Motoring View Post
    No problem, good luck.
    Lots 'o Goodies
    Oct 13 2007
    The 215 & 302
    Got the two (POS) today and coil packs... Car running great thx for the tip
