So my car started stuttering and sounded like a subie so i searched the forums for some results and found that it was most likely the coil packs. So I used OBD scanner and got cylinder 1 misfire. I tested the pack by moving it to cylinder 4 and resetting the ecu, then i got cylinder 4 misfire. Ok so i bought a new CP and everything was good. I decided to turn the car off and on 1 more time before i closed her up, but the car wouldnt start??
I used the OBD scanner again and got code P0688 ecm/pcm power relay sensor circuit open. Any ideas on what this could be????
Thanks in advance guys!
