Results 1 to 2 of 2
    Apr 12 2008
    2011 Audi A6 Avant 3.0T; Past: 2006 Audi A3 2.0T
    AEM intake throwing engine codes
    So I've had my AEM cold air intake for over a year with no problems.
    The other day after driving about 40 minutes on the highway, I get to some local streets and hear a strange high pitched humming noise at very low speeds - almost thought it was my brakes. At speed it was no problem, but at low speeds, the sound was pretty loud. Then the car started idling weird - the needle would bounce up and down a little. Then the dreaded CHECK ENGINE light comes on. CRAP.
    I take it to the dealer the next morning, and they blame the aftermarket intake. The codes that came up were :
    P0507 (idle air control system RPM higher than expected) and
    P2187 (system too lean at idle, bank 1)
    They said maybe the intake's just dirty, has a leak, etc, but since it's aftermarket, they can't service it. Now I don't have the time to check the filter until the weekend, but I noticed it only makes the noise after driving around for a while (or when it's hot?)
    Anyone have any idea what might be wrong? Thanks in advance.
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: AEM intake throwing engine codes
    I doubt it's your intake. How often do you clean it?
    My guess is that you have a vacuum leak. A boost gauge would help.
    Also, in posts like this.. it is very wise to post your cars model, year and engine.
