Results 1 to 14 of 14
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    What is the lowest offset on a 18x8.5?
    What is the lowest offset anyone is running on some 18x8.5's? I know the OEM RS4 19x9 et24's wont work, but what about an 18x8.5 et25. I don't want mad poke or stretched tires.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: What is the lowest offset on a 18x8.5?
    ET30 with 225 series tire
    Veteran Member Three Rings jstahmann's Avatar
    Feb 21 2005
    2008 RS4 - Imola/Titanium
    Utah, USA
    18 x 8.5 ET 35 BBS CH with 235/40 18s + 8mm spacer = ET28
    John
    Piggie Pipes|Flowmaster 40s|Stasis SLs (800/1200)|Hotchkis Sways F&R|Suede Euro Steering Wheel|Apikol Rear Diff Mount|034 Track Transmission Mount|SilverRS4 PnP Intake|JHM IM Spacers|Status Ring Alcantara Seats|Euro Tails|Rotiform Forged SNA 19x10|285/30/19s|Bonneville 130 & 150 MPH Clubs
    RS4 REGISTRY
    Mar 24 2007
    I won't be that low and will be running a 235/40/18. Any pics with the CH & spacers?
    Feb 21 2005
    Utah, USA
    Here are a couple...
    18x8.5 ET35 running 235/40 18. 8mm spacer rear, 5mm spacer front.
    18x8 ET33 running 225/40 18. 8mm spacer rear, 5mm spacer front.
    No rubbing on the street with either setup. For suspension I'm running Stasis SLs with the standard A4 600 front/1000 rear spring rates. Will be replacing with 700/1100 springs in the near future.
    John
    RS4 REGISTRY
    Jun 11 2005
    Vancouver, BC
    My original reply was referring the front wheel offset only as it is most important.
    With the 5mm spacer you are at ET30 as I mentioned. A 235 is as wide as you can go with minimal rubbing. The 225 is a bit safer.
    Feb 21 2005
    Utah, USA
    Quote Originally Posted by [email protected] View Post
    Didn't see that mentioned anywhere in your post.
    Actually with the black wheels I'm at ET28 in the front since they are ET33 to start with. Again, no rubbing, and I've run a 235/40 on that wheel as well.
    I'm now running the 8mm spacers front and rear with the CHs without rubbing.
    I run 255/35s on the CHs at times without rubbing, so it's really a matter of testing what fits and what doesn't.
    John
    RS4 REGISTRY
    Veteran Member Three Rings A4 JooN 2.0T's Avatar
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    sorry to thread jack but.....how much more grip would you get from 225 oppose to 235???
    2007 B7 A4 2.0t Qtip Brilliant Black on Black -=- Revo Stg 2/SPS2 -=- Milltek Catback Labree Quads -=- Eurocode Testpipe -=- K&N Filter -=- Forge DV -=-RS4 Rear Sway -=- ECS Quick Spool Pulley -=- Neuspeed SS -=- 20% 3M Tint -=- Lamin-X Yellow Fogs -=- LED UV Blacklight Interior Lights -=-O.Z Ultraleggera Black w/ Yokohama S.Drives
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Corrected:
    Quote Originally Posted by A4 JooN 2.0T View Post
    sorry to thread jack but.....how much LESS grip would you get from 225 oppose to 235???
    Answer: about 10mm worth.
    2006 Audi A4 2.0T Quattro 6MT S-line
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by INTEGRATION View Post
    Corrected:
    If you are not tracking, then you'll me more then fine.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Oct 03 2005
    06 A4 2.0TQ 6Spd
    Northern NJ
    Quote Originally Posted by jstahmann View Post
    Absolutely perfect car set up.
    Got any more pics with those 18" BBS's???
    Jan 06 2008
    Dacia Sandero
    Arizona
    18x8.5, et33 235/40/18 kdw2 on sport suspension... any rubbing issues i should know about? wheels aren't due back till next week. damn.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    On sport suspension which of these will rub?
    ET30 - 18x8.5 - 245/40/18
    ET30 - 19x8 - 245/35/19
    ET35 - 19x9 - 245/35/19
    -Kris
    AWD_4TW
    Quote Originally Posted by VMRWheels View Post
    -Charles@VMRWheels
    Very true. But Peter (@ VMR) knows how I am
