Results 1 to 8 of 8
    Veteran Member Four Rings Grouse's Avatar
    Sep 06 2005
    05 a4 3.0 Ultrasport
    Norwalk CT
    3lg Detailed Pearl Acura TL
    Mothers day present. This Acura TL fell victim to a son who decided to wash her beloved car with a green scotch bright pad and sponge combo. Upon first inspection i was actually quite worried that he had scrubbed through the opal layer in the clear coat. The vehicle had a heavy layer of embeded dirt and grime making it almost a cream/toupe opal. Instead of the bright white of the areas he scrubbed off.
    It was pouring out in the morning; I did not have an opportunity to take before pictures of the whole car. I had pulled it in, Washed it with ONR and then clayed it. After taping I proceeded to take these before shots. The areas with no shine are the scrubbed areas, not dirt. You can see here some of the initial color cast (taupe) of the car.
    I need to give props to my wonderful light holder, mike. He does an excellent job. He wants you all to know he is available for birthdays and batmitsfas
    USPClub Member # 32
    Nominated best detailer in western washington
    Chosen as one of the top 9 detailers in the US by autoweek.
    Sep 06 2005
    Norwalk CT
    Re: 3lg Detailed Pearl Acura TL
    Here is a 50/50 shot of the first picture above
    Before
    After (keep in mind this was just after compound phase, not final polishing.)
    This is the hood after all the polish steps. For reference the steps were:
    Schlegel #1 wool cut with 1z intensive paste x3 on the trouble areas, x1 on lighter areas
    Green lc pad 106ff on the whole car
    white LC 1z metalic
    1z glanz wax.
    another angle.
    Outside photo’s in the afternoon sun.
    USPClub Member # 32
    Sep 06 2005
    Norwalk CT
    Passenger side with pictures taken with the sun gun.
    USPClub Member # 32
    Sep 06 2005
    Norwalk CT
    Final shot as it looked in the sun.
    USPClub Member # 32
    Nov 13 2007
    '07 A3 2.0T
    Tampa, FL
    Quote Originally Posted by Grouse View Post
    [O_O]
    That is an impressive job! I would have figured that was going to need a repaint, well done!
    Veteran Member Three Rings ewytt's Avatar
    Sep 19 2006
    2016 SQ5, 2012 Turbo Beetle
    Scotch Pad!?!?!
    2016 SQ5 || 2002 Turbo Beetle
    Stage 1 Advertiser Two Rings Mike @ einszett's Avatar
    May 03 2007
    Austin, Texas
    That is a fantastic turn around! Aaron, what speed did you apply Intensive Paste?
    Great work
    P.s. Mike, great work with the lighting
    Mike
    einszett North America
    german waxes polishes cleaners | since 1936
    [email protected]
    www.1z-usa.com
    888-719-4698
    The einszett Detailing Guide - Articles, Terminology and More...
    Sep 06 2005
    Norwalk CT
    thanks for the samples,
    About 1500rpm
    USPClub Member # 32
