Results 1 to 7 of 7
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Vag Codes: P1114/17522
    Just pulled the codes off a friends B6 1.8.
    Thought Id post it in here since it is a 1.8t too.
    7522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
    P1114 - 35-10 - - - Intermittent
    I got those codes with some symptoms:
    -misfires on all cylinders
    - lack of power
    -checked plugs already
    -rough idle and drive
    -block 32 values are in spec
    When I disconnected the MAF it idled fine.
    I'm thinking its the MAF
    anybody wanna chime in?
    -thanks
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Re: Vag Codes: P1114/17522
    bmp
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    vump
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    From my unfortunate experiences, a bad MAF would definitely give those symptoms!
    Log block 003 or switch it out with a good compatible MAF from another car to help verify.
    Established Member Two Rings oneighty's Avatar
    Aug 30 2007
    any results on this. was it the MAF?
    -Jonathan
    '00 A4 1.8T K&N | InMotion Tuning | Forge004 | AutoMeter boost gauge | Eibach ProKit | ST sports | Avus S4 | 6000K HIDs
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    That just means the rear O2 sensor heater curcuit is going bad. Does that even trigger a CEL? It's an interminnent code.
    To check. Take a multimeter and disconnect 2nd O2 sensor from its harness behind the coolant reservoir and check resistance between wires 1 and 2. Wire 1 is all the way to the left. Resistance should be under 20 ohm.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    If you have a vag and it has a rough idle, check the mass airflow g/s at idle and tell us what it is. this will tell us should be around 3g/s at idle. when mine failed it was showing 25-30 needless to say i was running pig rich.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
