Results 1 to 10 of 10
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    B & M Short shifters
    So who likes em? Who uses em? Couldnt get the search engine to work with the name b and M so why not just make a new post!
    Senior Member Two Rings keithla4's Avatar
    Oct 31 2007
    02 audi a4 quattro man
    oregon
    Re: B & M Short shifters
    b&m dosent make the short shifter for our cars anymore i have already called b&m direst and they told me there wasent a big enough demand for them so they cancled them. sorry to tell you that.
    Sep 24 2007
    Woodbridge, Ontario
    lol I bought one off a member on here. Its going out tommorow.
    Veteran Member Three Rings MarkChai's Avatar
    Feb 01 2007
    1998 Titus Quasi-Moto
    SF, CA
    I have one in the garage that is missing hardware, and since B&M doesn't make the shifter anymore, I have an anodized paper weight.
    Formerly:
    B7 A4 Saloon CVT :P
    C4 A6 Avant Quattro
    B6 A4 Avant USP 6QM
    B5 A4 Saloon Q-Tip
    Veteran Member Three Rings TurboQuattroPwr's Avatar
    Sep 28 2006
    Delaware
    I have one and so far no complaints. I have it on the shortest throw setting and its almost effortless when it comes to shifting though the gears. B&M FTMFW!!!!
    2018 Audi S4 3.0T
    18% Tint, CquartzPro Ceramic Coating
    2002 Audi A4 1.8TQM *Gone*
    Veteran Member Four Rings tamadrumr88's Avatar
    Nov 03 2006
    lehigh valley pa
    I drove a MK4 GTI with one and I absolutely could not get it into 2nd gear... It felt mechanical yet sloppy, not tight (Like a stock shifter perhaps with metal shifter bushings) I'd probably go with the ebay B&M knock-off seeing as how it's only $30 and wouldn't be as much of a loss if it truly sucked
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    there are other brands you can choose like Hypershift or JHM
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by keithla4 View Post
    Yeah once the JHM hit the market that demand for B&M went out the window. Just cant get any better then the JHM shifter since it replaces all of the parts not just the shaft.
    Senior Member Two Rings Sammy7's Avatar
    May 03 2008
    2003 A4 Avant, 1985 320i Baur
    San Angelo, TX
    Quote Originally Posted by tamadrumr88 View Post
    I'm wondering how much of this is the shifter itself and how much is the way it was installed and adjusted. When I installed my Neuspeed, it took some trial and error to get it right. There has to be a good number of people out there who thought "Screw it. I can get it into every gear and that's close enough."
    That being said, I wasn't satisfied with my Neuspeed because it still used the plastic ball and the whole assembly still rode on the rubber bushings. The only benefit came from the change in geometry that gives you the shorter throw. When I saw the comparison video on the JHM website, I was sold.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    I had a B&M on my B5... worked great, just had a little side to side slop while in gear. The JHM looks like a better shifter though.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
