Results 1 to 12 of 12
    Jan 01 2008
    Long Island NY
    Looking for an Intercooler, any recomendations?
    I want to spend about 400 bucks + or - 75 bucks. I feel like the AWE is way overkill so i dont know which to buy.
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    Re: Looking for an Intercooler, any recomendations?
    maybe a used gretty..............or save up and do it right. It may be "overkill" but it does not get heat soaked even with hours of racing.
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Jan 01 2008
    Long Island NY
    I think i may go with the Godspeed one on ebay, it looks very similar to the gretty set up. what do u think???
    Sep 24 2007
    Dallas
    Quote Originally Posted by Auditude2.0T View Post
    similar does not usually mean close. The big manufactures spend atot of time on fluid dynamics and end baffeling. I do not think the little guys do much of any testing
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    Pete, get the greddy if you are going to get one. the AWE is great also just not entirely necessary for the street driving. I would say if you are tracking the car regularly and have a bigger turbo then def get the awe but for not with the stock turbo and street driving the greddy is great, thats what i have. Its the cheapest one out there and works well and looks nice. If you want when i see you tomorrow i will give you my run down on the whole principals behind it.
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    wow you are putting on every possible mod for our K03's and on a TIP!!... I'm excited but you def need to get to the track!
    Registered Member Two Rings coryliv's Avatar
    Feb 09 2006
    VA
    Perhaps I'm missing something but the Greddy kit for the 2.0T is almost $1K. I hope your variance has changed to + $600.
    ________________________
    2006 A4 2.0T Quattro
    Moro blue, grey leather, 6 spd, sports suspension, GIAC, RS4 rear sway
    Jan 01 2008
    Long Island NY
    Thanks everyone, i think im going with the Greddy.
    In Limbo Three Rings
    Jan 18 2008
    2006 A4 2.0T quattro mt
    central jersey
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    GReddy or AWE!
    2006 Audi A4 2.0T Quattro 6MT S-line
    Stage 2 Banner Advertiser Three Rings Todd/AWE's Avatar
    Mar 19 2004
    Willow Grove, PA
    Quote Originally Posted by extremesport3 View Post
    We have done EXTENSIVE testing on many different intercooler core sizes and tubing sizes on the B7 2.0T, both with stock and larger turbos.
    Because the factory uses a dual intercooler setup stock, it is extremely difficult to improve upon it.
    Without going to the size that we did, not only would the results not be an improvement over stock, they would most likely be worse. We saw this during R&D.
    If the B7 2.0T came stock with a single IC like the B6 1.8T, it would be much easier to design a better system.
    Yes, there are cheaper systems out there for the B7 2.0T, but our research indicates that none of them could be improving over the stock design. In that case, what is the real value of them? Just to look cool?
    Trust us, if we could have gotten away with a smaller core, it would have made our lives much easier (and costs much cheaper). Our kit is designed with street driving in mind, even though it has been limit tested at the track.
    Hope this helps!
    Todd Sager > President
    AWE-Tuning.com > 1.888.565.2257
    facebook > twitter > YouTube
    Jan 18 2008
    central jersey
    you should make your intercooler say AWE on it or the 4 audi rings
