Results 1 to 17 of 17
    Dec 24 2007
    St. Pete,FL
    coolant leak from HELL!!!
    so i have had a pesky little coolant leak for over a month now and i have just been dealing with it putting more coolant in....after looking at it its coming from the coolant sensor on top of the rear coolant flange. took it out changed the o ring twice now first time same thing, this go round i had to pull over in a parking lot bc it was over heating! im so aggravated! i guess im just gonna tow it to the dealer tomorrow....i just want it over with
    Saint Cloud, Fl
    Re: coolant leak from HELL!!!
    I replaced my I rear coolant flange in about 3 hours.
    instagram ------------> low_enforcement
    Senior Member Three Rings AudiSeefu's Avatar
    Sep 14 2006
    Fort Myers, FL
    yeah, sounds like it is definetely the flange.
    http://members.cox.net/audiche/maxfrontsigtemp.jpg
    -Che
    1998 Audi A4 2.8
    2002 Audi A4 1.8t
    Feb 17 2005
    Sarasota, FL
    How come you didn't mention it earlier? Probably the coolant flange as said and changeable in about an hr
    Dec 24 2007
    St. Pete,FL
    its not leaking on the block though its running down the flange and dripping on the tranny....its definitely coming from the sensor bc the o ring isnt sealing right at all
    Feb 17 2005
    Sarasota, FL
    Don't tow it to the dealer, bring it to me, we'll take care of it (and for much cheaper). The flange's do crack where the quick fittings clip in, we are actually changing out a flange on a B5 tomorrow. Thought it was a hose (which one was cracked) but the flange is cracked as well.
    Dec 24 2007
    St. Pete,FL
    im gonna put the old o ring back in tonight as i was at least able to drive with that one......a tow to sarasota is gonna be rough on the pocket
    Feb 17 2005
    Sarasota, FL
    No AAA?
    Dec 24 2007
    St. Pete,FL
    not i sir....maybe my mom but i dont think so
    Veteran Member Three Rings chimchongdlight's Avatar
    Jan 02 2007
    Bay Area to Sacramento Ca
    ok so i think i have this problem too, where is this so called flanged located? i have a coolant leak too, and as i look for it, i see it in the back of the motor near the firewall, looks like a plastic thing from a sensor that plugs into, now is that what u guys are talking about? are there any pics? bc i need this done asap, i went thru two gallongs of g12 in two months
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Quote Originally Posted by chimchongdlight View Post
    Look on the B6 DIY page and there is a write up on changing the flange. Took me a lil over hour but time could chance depending on your tools at hand.... Sounds like it is deff. your rear coolant fange. Part is about $20 from the dealer I think.
    Jan 02 2007
    ok so what is the specific name of the part so i can go buy it? o and also i drive a b 5, will it be the same or wat?
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    Quote Originally Posted by A4ringedONE8T View Post
    An hour? Christ! it took me a knuckle busting 5 hours yesterday.
    -Ryan
    2002 1.8t Quattro
    Mar 14 2006
    2011 VW Touareg Executive V6
    Just did mine a few weeks ago. Same symptoms. Took a few hours to get it out, but was much easier to put new one in.
    Aug 28 2007
    ok so what is the specific name of the part so i can go buy it? o and also i drive a b 5, will it be the same or what?
    "Rear Coolant Fange"... Someone correct me if I'm wrong but it should be the same for B5's also. But have your VIN number when you go, because the parts guy said the style changes a little depending on the year.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Quote Originally Posted by SmokdOutA4 View Post
    dripping on the transmission is exactly what it will do when the flange is leaking. Mine did the same thing, there is an o-ring that is set in a groove and there is a thin wall that holds the o-ring in place which cracked on mine so it was leaking. Others have had the actual flange crack. I bought a new flange from the VW dealer by telling them what my car was and they had them (from a Passat), it's a little cheaper than the Audi dealer.
    Here ya go click
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Registered Member Two Rings I Audi5K I's Avatar
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    funny story, just happened to me this morning....$371.00. shoot me in the face.
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    | Revo Stage 1 | RNS-E | Racetec FMIC | Milltek Exhaust |
