Results 1 to 3 of 3
    Registered Member Two Rings
    Jan 14 2008
    A4 Avant 1.8T 02
    Montreal
    OEM Sub style antenna install
    Hi there,
    I am working on a retrofit OEM Sat antenna on my avant A4-02. I will need to drill a hole on my roof and just wanted to know the best way to go about doing this install without damaging the roof ! Also, can anyone tell me what type of glue/sealer would be best once antenna is bolted on ? Id like to do this right the first time around without any leaks...
    Thnx,
    Oli
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    Re: OEM Sub style antenna install
    Quote Originally Posted by mtlavant View Post
    Hi there,
    Thnx,
    Oli
    i say skip the install and just use the ones that can be mounted on the dash or behind the unit.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Jan 14 2008
    A4 Avant 1.8T 02
    Montreal
    The thing is im also installing a SAT receiver which was never pre-wired in my car. So I don't think I can use the Sat without the antenna hooked up to the roof.
