Results 1 to 13 of 13
Thread: P0116
    Senior Member Three Rings audihtp's Avatar
    Sep 28 2007
    Levittown, NY
    P0116
    I see the code popped up.
    where is the coolant temp sensor located?
    and anyone know the part # for 99 2.8?
    Apr 18 2007
    ny
    Re: P0116
    Its under the coolant expansion tank.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: P0116
    on the 2.8 its sort of under the MAF near the throttle body
    if you look under the MAF near the back of the engine you should see a blue/green top fastened in place at the end of a metal tube
    change it before you get stranded, dont forget a new oring
    btw purems.com sells it for less than $20 iirc
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Sep 28 2007
    Levittown, NY
    Re: P0116
    cool thanks man. I'm going ot try to et the parts today..... since I gotta long drive this weekend.
    Sep 28 2007
    Levittown, NY
    Re: P0116
    so I saw Blue top when I look under there. so that's square one not revised one right?
    I got it for 30 at dealership....
    Sep 28 2007
    Levittown, NY
    Re: P0116
    haha I guess I found teh instruction...
    http://www.audiworld.com/tech/eng47.shtml
    that blue one that I see on mine. so I guess I got the right parts.
    well I have to go to client's house today so on the way back swapping the car and let it cool off. then when I get off work, I'll try swapping it
    Nov 20 2005
    Re: P0116
    my bad in regards to the proximity of the maf... its closer to the throttle body
    anywho here is the right writeup...the one you posted is for a 1.8
    http://www.audiworld.com/tech/eng108.shtml
    is it 4:20 yet?
    Sep 28 2007
    Levittown, NY
    Re: P0116
    OC-Drop,
    thanks man didn't know there is the right instruction with right pic.
    so I got the o-ring and sensor. even though my CEL went away but replacing it anyway since it's got
    about hit 150K miles. and looks like gonna have to do it tomorrow.
    next I guess to have trans oil/filter change and have independent place check the axle etc.
    Nov 20 2005
    Re: P0116
    I forgot to say you might need a new clip for it as well =)
    always good to change before it goes completely bad... it stranded me on the way home once... it was a whole weekend ordeal that sucked!
    is it 4:20 yet?
    Sep 28 2007
    Levittown, NY
    Re: P0116
    yeah shouldn't be that hard to remove the clip without breaking it. my hands are small enough to fit that space without removing duct I tried but engine was hot... but able to to pu my hand in there.
    well just update, I was able to take the clip from harness and take connectors out. but had to stp it was still hot!
    so will see how it goes tomorrow.....
    Sep 28 2007
    Levittown, NY
    Re: P0116
    Quote Originally Posted by oc-drop View Post
    yeah went to get new clip this morning. dealer right by my office.
    so hope rain stops in the afternoon.
    Sep 28 2007
    Levittown, NY
    Re: P0116
    I was able to do it but man it was tight squeeze to put both my hands in there and trying to put clip back on.......
    but man what a difference with new sensor... I guess it was bad to begin with, it's running much better than before...
    thanks for the info to OC-drop.
    Sep 28 2007
    Levittown, NY
    Re: P0116
    ride smooth all the way upstate took 3 hours though with traffic.
    and this morning, I just did
    http://forums.audiworld.com/a6/msgs/700362.phtml
    so I'm gonna take it for ride and see how it feels!
