Originally Posted by
oc-drop
it doesn't say it is an issue for 99-00
i wonder if i should be concerned?
digga what caused you to believe the tank was malfunctioning?
There was fuel spraying out of the top of the tank
The scary part was this went on for sometime (months). I kept smelling something on some mornings but fuel evaporates off so quickly that there was never a puddle or anything to identify where it was coming from or what it was. Later I realized it was only on days that I had 3/4 tank or more
I am pissed because I know damn well this was going for sometime and progressively getting worse, I truly feel that it was ignored at the dealership while I was under factory warranty because I had mentioned a strange odor multiple times before and they never found anything but the first time I saw my car on a lift It was obvious from the drip stains on the tank that I had a fuel leak. You think they would have taken it a little more serious
What would happen was after I would fill up my tank and it was pressurized it would then force the gas through the leak... literally spraying out towards the end...(god imagine how much gas I wasted
I actually had it in a local VW/Audi shop-Fixx Tuning for some other things and was complaining so they actually found the fuel leak! We replaced the fuel sending units, but this did not correct the problem so thats how it led up to the true problem.
With as long as I drove like this I am lucky I didnt spontaniously combust.
Sorry for the length but believe me this is the short version of the story
