Results 1 to 14 of 14
    Veteran Member Four Rings AudiBoy808's Avatar
    Sep 28 2004
    99.5 A4
    Honolulu, HI
    FS: KMAC Front Camber/Caster Kit
    This kit is brand new I never opened it was going to use it on my 2.8 fwd but I've decided to go CO's instead. So if anyone is looking for a good camber kit for their car here it is.
    According to box this kit works on Audi's:
    A4, S4, A6, S6, A8, S8 (95 - 05)
    VW Passat (97 - 05)
    Asking $250 shipped which is what I paid for the kit.
    99.5 silver A4
    FI CF hood | Eurogear CF Euro trunk | Eibach Pro-St coil overs | Crimson K6 | Kerscher frnt | Avant garde sides | RSR Rear | Vibrant exhaust | Silver CF rear seat inserts |
    Registered Member Two Rings
    May 12 2008
    01.5 S4
    Irivne
    Re: FS: KMAC Front Camber/Caster Kit
    Don't you need this kit if your running coilover's
    Sep 28 2004
    99.5 A4
    Honolulu, HI
    Quote Originally Posted by superdug_17 View Post
    I don't think so none of the guys in our group have any camber issues with their coilovers. So I'm thinking the same will go for me.
    99.5 silver A4
    May 12 2008
    01.5 S4
    Irivne
    oh ok cool. well guess I don't need then either. good luck with the sale. free bump.
    Veteran Member Four Rings alen's Avatar
    May 11 2004
    1.8tqms
    ghettlanta
    what all is included in this kit?
    Sep 28 2004
    99.5 A4
    Honolulu, HI
    Quote Originally Posted by alen View Post
    Ok here's what you get in this kit.
    VW Passat (97-04). Audi A4 / S4 / RS4, A5/S5, A6/S6,A8 ('95 -'08), Skoda, Octavia ('95-'06)
    #140916H $320 - pair
    K-MAC Patented Camber & Caster kit design replaces upper / inner control arm bushes providing precise single wrench adjustment. Includes bush extraction / insertion tools.
    This was taken off KMAC's website and is the exact same kit I'm selling.
    99.5 silver A4
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by AudiBoy808 View Post
    I think it's possible to be out of spec up front with camber if your car is too low on the CO's. Not sure.
    Veteran Member Two Rings DinoB's Avatar
    Mar 30 2005
    Civic, Pilot, RS 6
    So. Cal.
    Quote Originally Posted by gq9 View Post
    I have to say false!!!
    The lower you drop your car, the more negative camber you will have. Doesn't matter if it's coilovers or lowering springs. You will need a camber correction kit to prevent tire wear.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Toe kills tires - not negative camber.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by onemoremile View Post
    Toe is the primary tire wear angle in a vehicle's alignment.
    Camber will also wear a tire. The Honda boys I used to work with dropped some cars low enough that the outer edge of the tire wasn't even touching the pavement. I aligned their cars to "spec" as far as toe. Even with a "pillow-ball" style upper mount I couldn't get less than -2.0* camber in the front of that car.
    They bought tires every other month, go figure.
    Yes, your car can be out of spec with lowering your vehicle. It's not as serious as other vehicles b/c we have upper and lower control arms.
    Aligning the vehicle is key. It's not that negative camber is bad, it's actually quite good. BUT you need to make sure that camber is equal on both sides. Camber issues can cause a pull/drift as well as make the vehicle feel squirrelly in corners.
    I forget the specs on the B5, but IIRC the front camber "stock" for sport suspension "1BE" is -1.0* Camber in the front and -0.7* in the rear.
    On a vehicle that has coilovers, or is tracked, autocrossed, etc., but still driven daily, -2.0 to -2.5* camber in the front is normal. I'm not sure about the rears "onemoremile" knows more about racing suspension setup than I do. Ask him.
    Registered Member Two Rings kuyagelo's Avatar
    Dec 05 2006
    san diego ca
    how bout 200shipped?
    Sep 28 2004
    99.5 A4
    Honolulu, HI
    Quote Originally Posted by kuyagelo View Post
    How bout $200 plus shipping.
    99.5 silver A4
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    ill do 200 plus shipping
    daworldisyours.com/forum<----check it out!!!!
    Sep 28 2004
    99.5 A4
    Honolulu, HI
    Ok bump, still up for sale last buyer fell thru.
    99.5 silver A4
