    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Question SS Brake lines question
    I bought these in the classifieds months ago as front B6 front ss lines. I got my calipers about a month ago and go to install them, but they do not look like the stock lines. Can someone verify if these are front or rear lines. One end look like the pictures below and the other end looks just like the one I took off the caliper. As simple as the question may seem, I am asking because I don't know but I ave a good idea what the answer is.
    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    Re: SS Brake lines question
    nop, you should go to ecs tuning and see how ours are... (if the ones in the pic above are acutaully the ones you got)
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
    Jan 18 2005
    Puerto Rico
    well, I was wrong... those are rear break lines for A4/S4
    FlexTuning
    Dec 08 2006
    Jersey
    what do you mean you were wrong? You first said they were not front lines, then said you were wrong they are rear lines?
    I dind;t judge by pictures because ACH Tuning has a pic of lines like the ones I have posted as front, and ECS Tuning has these pictured as rear. Someone please help
    Dec 08 2006
    Jersey
    Still need help with this, don't want to order an unnecessary set of brake lines
