Results 1 to 16 of 16
    Mar 10 2007
    Cincinnati
    FI x pipe with 8 inch resonators cat back
    Does anyone have a sound clip or video of the FI cat back x-pipe with the smaller 8 inch resonators? I have searched with no luck. I would love to hear it before I pull the trigger. Thanks.
    Senior Member Three Rings iluvTTs's Avatar
    Oct 23 2007
    Re: FI x pipe with 8 inch resonators cat back
    I have no way to get a sound clip up, but I have this system and HOLY HELL it is hands down the best mod I have ever done to any car, hands down! You will LOVE driving and have a real hard time keeping off the pedal. PULL THE TRIGGER!!!!
    Registered Member Two Rings mus27's Avatar
    Mar 17 2008
    B6 S4 Negaro
    What's the other option with the X-pipe? 14" resonator? iluvTT's..where in CT are you located? I am in Manhattan and would love to hear your exhaust if you have the 8" resonator? Is there any drone at highway or cruising speeds?
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    I'm curious about highway drone as well. How is it around 3k RPM?
    EDIT:
    Not sure what size of the resonator was on this one but if it is same one it sounds pretty sick
    http://www.youtube.com/watch?v=kMqMeWA9nCw
    Mar 17 2008
    B6 S4 Negaro
    Quote Originally Posted by 40valve View Post
    EDIT:
    That's a Fullback so it will be louder than the catback. Also, if you look at the beginning of the video it looks like the resonators are longer than 8"..i could be wrong.
    Mar 24 2008
    khgkhg
    Quote Originally Posted by mus27 View Post
    Ah, I missed that first part. You are right, those resonators are longer than 8".
    Senior Member Three Rings snowbird's Avatar
    Nov 20 2007
    '04 S4, '11 Q5, '90 Corrado, '96 911 C4S
    Toronto ON
    I also purchased the 8" x-pipe setup, but haven't got it installed yet. Can't wait!
    Mar 17 2008
    B6 S4 Negaro
    Quote Originally Posted by snowbird View Post
    catback or fullback?
    Nov 20 2007
    Toronto ON
    I got a catback
    Veteran Member Three Rings Speedymon's Avatar
    Aug 27 2005
    2004 S4
    San Antonio, Tx
    i have this setup. Down low its deep. Around town its pretty quiet and you'll hardly know its there. I've driven females around and its not obnoxious and you can hold a convo easily. I'm actually thinking about taking the 8" resonators out to get more sound. Very very civil.
    But no sound clip.
    Imola_Jon's supervisor...
    Nov 20 2007
    Toronto ON
    getting mine installed on Friday!!
    Mar 12 2007
    Boston
    EDIT:
    I have a Labree Resonated catback. Very similar to FI in terms of design and hardware (Sebring mufflers.) There is ZERO highway drone. The drone occurs only at 1600-1900rpm. It's a very, very small window, BUT if you're a gear too high for any reason, it is VERY loud. Honestly doesn't bother me in the least, though, because the damn thing just sounds so good. Some have said Labree and FI are raspy, but I completely disagree. It's a deep burble at low rpm and rises to a beautiful, rich tone above 3000rpm. Sounds mean but in a classy, unique way. Definitely does NOT sound like an American muscle car as some have described.
    Established Member Two Rings AudinLV's Avatar
    Jul 09 2007
    S6 RS6(RIP) S4 Ducati M Dark
    LV, NV
    Quote Originally Posted by tadhgbrosnan View Post
    Totally argreed! I have the FI set-up and I LOVED the European sound.++1
    Veteran Member Three Rings RenoAudiNV's Avatar
    Feb 10 2007
    Reno, Nevada
    I have a F.I. fullback xpipe (resonated)...not sure of the resonator size. But the sound is just what I was hoping for. See my sig for some vid clips. There is some drone but only in very low rpm (1200-2000), not a problem at all for highways.
    Silver 2004 S4 Avant
    --Current Setup--
    Fast Intentions Downpipes || Fast Intentions Perf Core Resonated XPipe 2.5" Catback || RNS-E || Sirius || 19" BBS CH || 235/35ZR19 Bridgestone Potenza SA050 Pole Position || Bilstein Coil Over PSS9 || Carbonio CAI || V1 Hardwired || VAGCOM || Votex Rear Spoiler || Oettinger Front Grille
    http://www.youtube.com/RenoAudiNV http://www.flickr.com/photos/davidcarrico/
    Mar 10 2007
    Cincinnati
    I want to buy this setup - but I want to make sure that it is loud enough - if that makes sense. I definetely want to hear the exhaust. any input??
    Senior Member Two Rings bklein8888's Avatar
    Nov 08 2006
    '06 Dolphin Grey S4
    SF
    Quote Originally Posted by abags9 View Post
    Corsa FTW...I have it and it's perfect! Look for the vid on youtube
    2006 Dolphin Grey S4 MT6
    35% Tint All Around
    Hoen Xenonmatch
    S4 Caliper Springs
    Corsa CB
    K&N Drop-In
