I have stg 2+ and I am running the car with a N75 and MBC. If I run the car with just a straight N75 the car will spike to 25psi ahhhh. If I put the car to stock mode it runs perfect and holds about 8-9psi?????? I have a brand new N75 and if I run the car with the MBC in parallel it works great but doesn't seem to pull as hard as when the car worked properly with just the N75. I have checked the plastic T's to and from the N75 and all seems fine. Could the GIAC tuning be at fault??????
