Results 1 to 9 of 9
    Senior Member Three Rings hey4's Avatar
    Feb 10 2006
    B5 A4
    Twin Cities
    Topic: Car idles funny - shoots flames etc. (long)
    So today as I was trying to fix my boost leak, I ran into some mayor PITA.
    Well first off I had no boost for the entire winter, beacause of major boost leak, so today I tried to fix it.Well I hooked up the air compressor to the intake side and figure them out. I fixed the leaks and started it up. Idles really rough, when I stepped on the gas it wouldn't go anywhere, it would be idling rough, missfiring. It eventually died and I had to push it home . Heavy ass car.
    Changed the plugs as they were fouled and some had oil on it. Put new plugs in. Idled funny, tried to drive it. It would not move although it ran smoother, not as bouncy idle. My dad gave it lots of gas and it stared shooting huge flames out. Turned it off before it melted my bumper. What do you think?
    No CEL, UNitronic tune, 3"maf housing, GT28rs
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Re: Topic: Car idles funny - shoots flames etc. (long)
    Perhaps some pics of the flames would be sweet!
    GL on the fixin though.
    Dec 05 2007
    I am no expert, but it seems to be a fueling issue. That is the only way I see it could have been shooting flames.
    Feb 10 2006
    B5 A4
    Twin Cities
    haha yeah I figured it was fuel but I am trying to figure out what's causing it.
    Also I am just perplexed by the fact that i can put the pedal all the way to the floor at times and nothing happens...
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    well its fuel or spark, maybe a coil? or fuel filter/pump? or possibly even the maf dissconect it and see what happens...
    Aug 16 2007
    Buffalo NY
    Hell if you have a cat may possibly even be a clogged cat..
    Feb 10 2006
    B5 A4
    Twin Cities
    spark is ok. I have gotten lead on the other forum that it is possible that I might have over-pressurized the crankcase. I am trying to figure out a solution on how to fix this?
    Registered Member Two Rings
    Nov 01 2004
    90 Celica All-Trac, 01 A4 1.8T
    Bothell, WA
    Roger
    90 Celica All-Trac
    01 B5 1.8TQ
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    i'm voting for maf is more than likely the culprit but it's hard to say at this point.
    Disconnect it and see if it runs any better, also could be a faulty temp sensor.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
