Results 1 to 2 of 2
    Senior Member Two Rings SnowBum124's Avatar
    Sep 14 2006
    1999.5 A4 1.8t avant
    seattle
    help with track rod???
    i was getting a vibration from one of my rear tires. so i put the car in the air and the only thing that i could see moving was this bushing(i believe its the track rod) i tried taking off the nut to remove the bolt to a better look. i got it loosen but now it just spins like the bolt is broken inside the bushing. i cant tighten or get the bolt off. any advise?
    BetaAlphaTau member # 40
    love my shag-in wagon
    GT2871R turbo, 630cc Siemens injectors, 034 Downpipe, SPAmanifold, TR11 FMIC, Maestro7, south bend stage 4, VR6 TB
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: help with track rod???
    That's the rear Toe Adjustment link.
    Since you've managed to get the nut most of the way off, and now have some of that bolt/joint apart. Get a set of "Vise-Grip" pliers and crank 'er down in the that gap getting a good hold on that bolt. If you have an impact, now is time to use it to get that nut off. Otherwise, I hope you can get a real good grip w/ the visegrips.
    This would mean you should replace that arm & "ball joint". So, if it comes down to it, just cut it off. You'll need an alignment afterwards
