Results 1 to 6 of 6
Thread: Tie rod help.
    Senior Member Two Rings detroittechno's Avatar
    Jul 03 2007
    DETROIT BURBS
    Exclamation Tie rod help.
    So I tried searching but found no answers. I just did a turbo swap and in the process found my tie rods were installed upside down by previous owner. WTF?? Well I switched them around and now both of my wheels are pointing in MAJORLY Both are pointed toward the center of the car like the wheels is turned halfway. How do I fix this??? I need to know how to adjust the tie rod??? PLEASE HELP! I have not driven my car in a month.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Tie rod help.
    if you changed the tie rods you need to get an alignment.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    Re: Tie rod help.
    Quote Originally Posted by RolledMySTi View Post
    Alignment is a Must....
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Re: Tie rod help.
    you should be able to turn some nut towards the base of the tire rod to change the length.
    Dec 06 2007
    Calgary, AB, Canada
    Re: Tie rod help.
    There is a lock nut on the tie rod end, which you can loosen. Then you can screw the tie rod end clockwise to go into the tie rod, or CCW to go out toward the wheel.
    Jul 03 2007
    DETROIT BURBS
    Re: Tie rod help.
    Thanks guys. I ended up removing them and replacing them. What a pain in the ass they are to remove. Here is a tip for you guys, 2 pipe wrenches come in real handy when removing old tie rod ends.
