Results 1 to 3 of 3
    Senior Member Two Rings WingsnHorns's Avatar
    Feb 09 2008
    '00 S4
    Vancouver
    Alignment in Vancouver
    Where is a good place to get my car aligned in Vancouver, BC?
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Alignment in Vancouver
    Go to Midway Excel Tire in Port Kells.
    Ask for Glen.
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    Go to PDM Racing - www.PDM-racing.com
    They are the sponsor of the local auto cross club - www.VCMC.ca
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
