Results 1 to 36 of 36
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Startup problem after letting it sit for a while
    The car does this only when its hot out and I have left it sitting for a few hours.
    I start the car and it acts as if its not getting enought fuel for about a full second. During that "second" the engine is hunting for idle. After that the idle goes to normal. I also noticed that if it sits for a while the car cranks a bit more before it starts, not much but I can hear the difference. If I shut it off and try restarting it it starts crisp (2 cranks and idle goes where its supposed to).
    On the other hand, if the car has been sitting and its been cool outside (less than 50 degrees) it starts crisp. It seems to be temperature related...
    Yes, I pressure tested...
    Any thoughts?
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Dec 06 2007
    Calgary, AB, Canada
    Re: Startup problem after letting it sit for a while
    Sounds like the fuel system is not holding pressure with the car off, so once the pressure has dropped off, the fuel pump has to run for a second or two before the pressure is high enough to crack open the injectors and fire the car up.
    Feb 22 2007
    Earth
    Hmmm, so how do I go about fixing this? and why is it happening only when its warm out. It starts just fine when its cold.....
    Dec 06 2007
    Calgary, AB, Canada
    Could be a bad FPR. Could also be a bad fuel pump check valve, etc. The best way to fix it is to use a fuel pressure gauge on the output line of the fuel pump while turning the ignition to the "on" position. If pressure is in spec, then try it after the FPR.
    Feb 22 2007
    Earth
    Update... today it was 85 degrees out.... after letting the car sit for 5 hours it took about 4 seconds worth of cranking for it to start. Temperature really effects the situations for some reason.... do you still think its a fuel pressure problem? Also, what fuel guage do I buy? any links? and where and how do you hook it up "to the outup line of the fuel pump" ? Any pictures? Also, where and how do you hook it up after the FPR?
    Pictures of the locations would be helpful.
    Thanks
    Quote Originally Posted by The_Jerbel View Post
    Dec 06 2007
    Calgary, AB, Canada
    fuel pump is in the trunk under the black plastic circular cover. There are arrows on it which show which way the fuel is flowing either into or out of the pump. The FPR is on the driver's side of the y-pipe and is a little aluminum cylinder. Hook up the hose of the gauge to the output nipple on the pump as well as the FPR.
    The gauge will have two hoses coming off of it and will enable you to hook it up inline with the fuel system. Any gauge will do as long as it's this style.
    2000 s4
    Fairfield, CT
    since they are about 20 dollars and fuel pumps are way more, get a coolant temp sensor and try that. when those start to shit the bed you can get extended crank and rough running. check for a MIL or see if any codes are pending but not stored yet for Coolant temp sensor
    i heart my s4
    Veteran Member Four Rings damnthemansam's Avatar
    Sep 20 2006
    motorcycles, boats, other cars and a longboard
    san jose, ca
    i thought that was where the evap canister was.. ?
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by damnthemansam View Post
    What are you referring to? fuel pump or FPR?
    Feb 22 2007
    Earth
    You mentioned the fuel pump check valve... where exactly is this located? Is it part of the fuel pump itself or is it a separate piece... would anyone know the part number of the "fuel pump check valve"? I replaced the fuel pressure regulator with a 4.0 bar from Vast but it hasnt really made a difference.
    EDIT: I should also add that the cluster displays ungodly hight outside temperatures.. for example when its 80 degrees outside it thinks its 140 degrees. Might the sensor that is reading outside temperature have anything to do with how long the engine takes to crank? Or running in general?
    Thanks
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    install a check valve like this drawing i made and your problem should go away. im guessing you have a walbro fuel pump?
    the check valve should be sitting just like how it is, but inside the red circle.
    Feb 22 2007
    Earth
    I have the stock fuel pump, but I dont understand what you mean by check valve... is this something thats oem or a modification that was done by you.. also what kind of checkvalve would I use.. dimensions and where you bought yours would be useful.
    Quote Originally Posted by nizmosx View Post
    Veteran Member Three Rings quicksilver_S's Avatar
    City that never sleeps
    Hows your battery? battery level has affect on temp and when you start the car?
    Feb 17 2008
    Ottawa Ont.
    the built in check valve on your fuel pump has most likely failed. Its possible the FPR is dumping pressure as well but less likely.
    Its really not a big deal. I have no check valve at all on my 044 pump and aside from it being a little harder to start, it really has no impact.
    Another possibility, is that the pressure feed line from fuel pump to the top of the tank (6 inch clear plastic line) has a hole in it. But again, not very likely.
    Feb 22 2007
    Earth
    Ehhh?
    Quote Originally Posted by quicksilver_s View Post
    hows Your Battery? Battery Level Has Affect On Temp And When You Start The Car?
    Feb 22 2007
    Earth
    I already replaced the FPR.. a small hole eh? Ill check it when I get a chance... if there was a hole there though woudnt I have gas all over the trunk? Or at least in the area where the pump is?
    Quote Originally Posted by BastardS4 View Post
    Feb 22 2007
    Earth
    How do you inpect the "pressure feed line"? Do I have to take the pump out? If so what are the steps in taking the fuel pump out?
    Feb 13 2004
    Lakewood, CA
    the check valve is a bmw part from a bmw 7 series i believe. you just buy it and put it where the picture shows. if your factory fuel pump check valve failed your car will hold no pressure in the fuel lines resulting in you having to crank the car a few times to pressurize it. install this check valve and it will keep some fuel in your line for the next start up. 7 dollar part from bmw. i dont remember part numbe.r
    Feb 22 2007
    Earth
    Alright, so the consensus is that the car is not getting enought fuel right off the bat, but why does it only do this when its hot out? Cause when its cooler it starts good everytime, but as soon as it gets hot it cranks more and starts very weak and then picks itself up.... I'm confused
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    Mine is doing pretty much the same thing too, I ordered another crank position sensor to see if that fixes anything...
    If that doesn't work Ill try the check valve.
    Let me know how the check valve works out and ill let you know the like about the crank position sensor.
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
    Feb 22 2007
    Earth
    honestly though, if it was a checkvalve it would do it all the time.. If I park the car in the garage (about 75 degrees) and come back 2 days later to start it it starts just fine. On the other hand if its hot out all it takes is a couple of hours and it just sits there and cranks and starts weak... It also seems to be related to how hard I drive the car before I park it.... If I floor it here and there, and then park it... come back after 2 hours to start it = crank heaven. EGTs were next on my list of things to do.... Idk, but I am thinking they are reading wrong on startup and the car is actually dumping too much fuel...idk.... someone correct me if my assumptions are wrong.
    Again, the car has had the following done to it:
    Giac x
    Baileys
    AWE IC
    Milltek turboback
    New fuel filter
    New timing belt and water pump
    New front o2 sensors from Vast
    New coolant temperature sensor
    OEM plugs gapped to .25
    NO CODES
    ALREADY PRESSURE TESTED
    Feb 17 2008
    Ottawa Ont.
    we have told you what to try first. stop over analysing it and try these simple things first.
    Feb 22 2007
    Earth
    What simple things, you mean installing a check valve? If it was a check valve problem then my question is "why is this not happening when its cold out and why does it seem to get worse if the time before I stomped the throttle a few times". You also said that the pressure feed hose is probably not it so I didnt delve at all into that one, plus its the 4th and I doubt I can go to the dealership to get a new one. I am just trying ot find an answer that makes sense, thats all. Now, my question is: "Would faulty or on their way out EGTs cause longer crank times? Temperature and weather I heatsoaked the engine the time before seems to have alot to do with this...
    Dec 06 2007
    Calgary, AB, Canada
    No.
    Feb 22 2007
    Earth
    Jerbel, welcome back! So, you still think its fuel pressure related even after what I said about heat affecting the situations so much? I was thinking it was a sensor of some some sort because of that. What do you think I should do next?
    Dec 06 2007
    Calgary, AB, Canada
    I would install the check valve. Well, in all honesty I would get a cheap fuel pressure tester and check the pressure to be sure of what's really going on. That way you can either determine it's a fuel problem, or completely rule it out.
    Feb 22 2007
    Earth
    Ok, i'll probably end up doing that.. I noticed when I was looking at the fuel pump today that the output and return lines are made of plastic... or a harder rubber, not exactly a good spot to T a fuel pressure gauge... where is the best place to put it? If you have access to it maybe you could post a picture. Thanks
    Edit: The fuel pressure gauge I'll buy will probably be this one: http://www.ecstuning.com/stage/edpd/...productID=5701
    So I need an 8mm ID hose that I can T this into. I was thinking of putting one before the fuel pressure regulator and one after. What would be some good T points? Again, a picture would help immensly
    Dec 06 2007
    Calgary, AB, Canada
    It depends on the connectors that the tester uses, but if possible, I would put the tester right where the fuel line comes into the fuel rail.
    Feb 22 2007
    Earth
    Yeah, that would be ideal, but I dont think the fuel gauge I posted about will work there. How did you do yours?
    Feb 22 2007
    Earth
    Ok, upon looking at it better I noticed on the top of the airbox there are 2 fuel hoses. One of them goes directly to the passenger side of the fuel rail. The other one goes directly to the fuel pressure regulator wich in turn plugs into the fuel rail. Wich one of these is providing fuel to the engine and wich one is returning it to the tank?
    Dec 06 2007
    Calgary, AB, Canada
    Feed line hooks up to the passenger side of the fuel rail.
    Feb 22 2007
    Earth
    You said its off a 7 series.... I called the bimmer dealer and he asked my what year car I had and all the other stupid questions that went with it. I told him what I wanted but he said I wasnt giving him enough info. I was wondering if you had any other info on this checkvalve.. maybe the year of the car.... the make you mentiones is the 7 series, but year, that I am missing. Or better yet, since you seem knowledgeble about this valve, maybe a part number?
    Mar 13 2006
    VA / MT
    Update??
    01.5 S4
    Stock S4 swaybar
    Feb 22 2007
    Earth
    Ok, so Installed the check valve thats talked about on this site:
    http://forums.roadfly.com/forums/bmw...1711019&page=2
    and I have to say that the problem has gone away... thanks bmw!
    Mar 13 2006
    VA / MT
    So I ordered the part from BMW early last week and they said it would be in saturday. I went in today to pick it up and they inform me that BMW no longer sells/makes this part... hmm...
    where did everyone else get theirs?
    This is kind of an inconvenience since I leave this weekend to drive across the country...
    01.5 S4
    Stock S4 swaybar
    Account Terminated Two Rings
    Feb 25 2006
    GA/FL
    Update with anyone that has had this issue?
