Results 1 to 7 of 7
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Help pretty, pretty please!! I can't figure this out!
    I have having some issues with my 2001 1.8t. I have NO boost leaks, gauge reads fine, NEW MAF, I have no VAGCOM... But I am boosting only 16 psi on my GIAC X... I used to boost about 22 - 20 and hold 18... But now it peaks to 16 and no higher... Holds around 12-13 psi... I am REALLY needing help with this one! If anyone in the Olympia, WA area has a VAGCOM, please let me know! I will give a 6 pack of your choice for helping!
    ΜΟΛΩΝ ΛΑΒΕ
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Re: Help pretty, pretty please!! I can't figure this out!
    I am a noob at this stuff, but have you tried to disconnect your N75 from the wastegate?
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    is it throwing a code?
    might be worth buying a vag-com
    Veteran Member Three Rings Naudilos's Avatar
    Mar 16 2007
    01.5 A4 1.8TQ
    Chicago/ Ann Arbor
    That's about what my car with a giac-x chip is running as well. Don't have any boost leaks and have a new maf. Once in a while it might hit 21-22psi but for the most part i'm holding 15-16psi. I'm pretty sure I dont have any codes, but it's been a while since I've had a chace to hook it up to a vag-com. If you find out what the issue is let me know.
    01.5 A4 1.8t Quattro Tip
    - Greddy III Turbo Timer - GIAC-X/Tip Chip - PSI Test Pipe - 2.5" Magnaflow Turbo-Back - S4 Euro bumper - UBERHĂUS RS4 grill - M3 Lip Spoiler - ProSport boost guage - Euro trunk lid - H&R Race Springs/Bilstein Shocks - S4 Side Skirts-
    18" RS4 DTM - 710n - 20% tint windows/tails/side markers - 6000K HID's -
    Mar 04 2007
    nothing
    nowhere
    I'll let ya know... I am getting a new DV because mine is honking anyways... At least I think it is the DV... I am thinking it MAY be the turbo though... I need to get some hemostats to block off the signal to the wastegate... Plus I have a whoppin CAPS time of 9.66... There is just something that ain't right... But on a good note, I am sticking with my wifes Hemi Magnum... It runs a 14.1 and runs it all day long... But I only keep up with her to about 75 mph... Then she rapes me...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Honking DV valve thats your problem right there. It's torn. By the way how do you know you don't have a boost leak? Did you pressure test? If you just did a visual inspection thats not good enough.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Mar 04 2007
    nothing
    nowhere
    Yeah, I let my compressor warm up and set it at 20 psi... I waited about 5 minutes and I guess it bled up to 35 psi! So when I tested, I was testing at 35 psi!! LOL!! But I honestly don't know if it is the DV or not... SOMETHING in that area is honking... It isn't the pankcake valve because that is new... The DV holds good vacuum when testing it...
    ΜΟΛΩΝ ΛΑΒΕ
