Results 1 to 18 of 18
    Active Member Two Rings neo's Avatar
    Sep 19 2006
    Virginia USA
    HIGH FLOW Catalytic Converter for B7 S4
    Guys,
    Need some input about changing the OEM Catalytic Convertergh to a HIGH FLOW Catalytic Converter. What is the consequenses and pros about this ?
    Thanks guys
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Re: HIGH FLOW Catalytic Converter for B7 S4
    I don't know of any high flow cats for our cars, but then again I haven't really looked around.
    Why are you interested in doing this? Gains?
    Veteran Member Four Rings trexturk's Avatar
    Mar 20 2007
    '11 Sprint Blue S4, 03 996 Targa
    Chicago Burbs
    well thats what the downpipes are. They replace the 4 stock cats and put 2 high flow cats.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    If you change DPs, don't you have to do the requisite chip? I thought I read that somewhere.
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Quote Originally Posted by channad View Post
    no you don't.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Mar 12 2007
    Boston
    Danny at Fast Intentions advises customers to reflash the ECU after DP installations. Otherwise, you run a greater risk of blown cats. I don't know the Xs and Os of why, but having researched various DP options this was one point I made a mental note of.
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    a) does not have to do with b)
    the real benefit is it helps with the car to see gains...gain maximum potential and certain softwares also have anti-cel software running...some do that others don't. i can't recall anyone saying you must run a chip if you do DPs on any vendors website. but if your looking to maximize potential/efficiency...then yeah go ahead.
    The RIDES:
    AMA Member
    JHMFTW!!
    Mar 12 2007
    Boston
    OK, I found the exact thread. It was Dodge2Dub's car. Having read it again, it appears as if a bad manifold may have contributed to both his cats going bad. BUT....the second posting in the thread mentions the DP/ECU point I referenced. Fast Intentions advises an ECU tune after DP installation. FWIW, I spoke to Brent Labree about a month ago and I asked him about this; he said the same thing.
    http://www.audizine.com/forum/showthread.php?t=185782
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    the part about blowing cats isnt about the ECU. I think what Danny meant is for them to take the CEL part out. Some cats have the wrong load on the cats while some do. When they have the wrong load, the CEL will shoot up. Make sure you get a catback exhaust system with the high flow cats.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Sep 19 2006
    Virginia USA
    Thank you guys
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    AWE DPs/high flow cats;
    AWE Tuning SS high-flow metal core cats/downpipes for B6/B7 S4 6speed
    $1899
    http://www.awe-tuning.com/pages/shar...ust&IL=b6s4dps
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Registered Member Two Rings 37doc's Avatar
    Oct 24 2007
    B7 S4,03 R1,04 Taco 4wd,75 RDs
    Southern Maryland
    I have the AWE DP's and can say they are great, build quality , support, sound , all great. The car sounds VERY aggressive.
    05.5 B7 S4,silver,6MT, black leather recaros,Carbon,Bose, cold weather,AWE DP's, Neuspeed cat back, GIAC 93/stock,Neuspeed short shift,BMC filter, RS4 pedals,shift boot/knob,and e-brake handle,DTM carbon rear spoiler,TCarbon rear valance,Kerscher DTM carbon splitter,DTH carbon engine cover, RS4 Optic grill, H&R swaybars,Hella optilux xenon H11 fogs,ECS snub mount,VMR 18" RS4's,stoptech F/R SS brake lines,Audi Rear sunscreen.
    Account Terminated Four Rings
    Apr 16 2007
    New Jersey
    damn, awe's dp's are expensive. FI's stainless dp's are still only 1550
    Mar 12 2007
    Boston
    Brent Labree quoted me $1250 for a set, and Mark at Autospeed quoted me $1200.
    Oct 14 2007
    Mammoth Lakes, Ca
    Quote Originally Posted by b00st View Post
    Posted by Dodge2Dub:
    "Well, I just got my car back yesterday and it turns out that I burned through both CATS in three months!! The passenger side CAT was completely hollow and the drivers side CAT had a 2.5 inch opening through the honeycomb!! I also had pieces of the CAT lodged in the exhaust pipes.
    With that said, FI completely took care of me and rectified the problem right away. We have come to the conclusion that the car runs lean at first due to the gained efficiencies causing the CATS to become super heated. The ECU responds by enriching the system and you end up with a hot/cold scenario that results in dead CATS. Also, I'm sure that the 91 octane isn't helping.
    We believe that the cure is to make sure you are running software that compensates for the gained emissions efficiency, especially if you are only able to get crap gas. Personally, I'll be running GIAC within the next few days."
    May 27 2004
    Portland, OR
    What cell count cats are FI using?
    Jeremy Williams
    May 27 2004
    Portland, OR
    Quote Originally Posted by 91gl View Post
    It's because they fit so well, include the highest quality metal cats, are true pieces of art, their service is unmatched, etc....
    You always seem to get what you pay for.
    Jeremy Williams
    Jul 21 2004
    South Florida
    Their comments make no sense since as we all know the S4 chips do not even require an exhaust upgrade and GIAC doesnt sell exhausts so it's highly doubtful they "tuned" for every exhaust out there and neither did APR and Revo. In fact some chips may even create higher exhaust gas temps then stock. The guy burned through his cats because FI uses cats that are simply OK in quality. Plenty of non chipped labree, FI, and even milltek cats have failed on both stock and chipped cars.
    cheers! mike
    2018 Audi S5
    Gone-
