Results 1 to 6 of 6
    Established Member Two Rings audinoobs4's Avatar
    Nov 07 2007
    Chicago
    Odd noise after wheel bearing replacement
    Alright guys another dilemma with the car. i had both rear wheel bearings replaced a couple weeks ago and everything was normal for about 250 miles. Then i get this weird clunking sound from the right rear only when i go forward. Does not make the sound when i go in reverse. I pulled the caliper off and the pads cuz i thought maybe they were loose or something but everything looks ok. Do you guys think this could be a defective wheel bearing????? Let me know what you guys think
    Nov 07 2007
    Chicago
    Re: Odd noise after wheel bearing replacement
    bump
    Senior Member Two Rings kengvang's Avatar
    Jul 11 2007
    2000 AUDI S4 TIP
    milwaukee, wi
    is it vibrating/ or ticking sound? at what speeds?
    Senior Member Two Rings quickdub's Avatar
    Jul 06 2005
    1973 Mustang Conv.
    CA/NJ
    was it torqued properly? These wheel bearings get a pretty hefty torque # plus a 1/2 turn...
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by quickdub View Post
    140ft-lbs plus 1/2 turn to be exact
    If the outer CV axle bolt isn't torqued properly, the bearing won't be compressed tightly like it is supposed to be, and will be ruined within a few miles.
    May 06 2004
    W124s
    PA
    Quote Originally Posted by The_Jerbel View Post
    Which equates to pretty much as tight as you can possibly manage...
    Keep right pass left, it's the law!!
