Results 1 to 7 of 7
    Established Member Two Rings BigChris's Avatar
    May 20 2007
    2014 Q7, 1992 MB 300SD, 1990 Miata 320whp
    Bergen County NJ
    What's this part called?
    I must be boosting too high since i shattered this piece in half on Saturday. Anybody know what the circled item is called?
    "It is what it is..."
    2007 Jeep Grand Cherokee Hemi
    1992 Mercedes 300SD
    2014 Audi Q7
    1990 Mazda Miata - 306whp @ 18psi - track car
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    Re: What's this part called?
    Boost Virginity - you broke it and you can't go back
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    its a oneway check valve that goes to your brake booster. It is very common to brake. new they are about 30 to 40 dollars depending on the dealership. What i did was i melted the two parts together and havent had a problem yet.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Yeah a very common valve that will go bad due to dry rotting and heat exposure. If you look around there are more than one in the system so check the rest while your under there to see if any others look like its there time.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Registered Member Three Rings
    Aug 06 2007
    02 Audi A4 1.8T Q Tip
    New Jersey, USA
    It's called a Check Valve
    I replaced 4 of them about a year ago. I paid $15.00 each at my dealer.
    You can also get them from ECSTuning.com CLICK HERE
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    That is the Check valve like stated above... I broke the suction pump piece (the one under that) on Friday, that I mentioned in your thread about stalling out... ECS to the rescue.. GL on getting her running right again
    May 20 2007
    Bergen County NJ
    thanks guys... i'm ordering from ECS right now... I have the car running right now by using duct tape to hold the piece together. I just cant' boost too much! :-)
    1992 Mercedes 300SD
    2014 Audi Q7
