Results 1 to 8 of 8
    Established Member Two Rings enzoballin's Avatar
    Jun 26 2007
    Beverly Hills
    Question How Would I Know?
    so i havent put an upgraded DV valve in my car, but i just want to know how could i tell if i tore it? and also could someone answer this, lately my car feels like its super slow until it hits 5k on the RPM, could it be the heat in LA and also running my AC really high? i am kind of confused...
    i appreciate all your inputs
    08 Brilliant BLK A4 Titanium Package Quattro
    GINTANI TUNED
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Re: How Would I Know?
    Heat will make you lose a lot of power. I can feel it too since I live outside of LA. It's been 100+ the past 3-4 days.
    About your DV, it will make a honking noise if it's torn.
    Jun 26 2007
    Beverly Hills
    is it bad to drive it if its torn? and also how far can u drive it torn?
    thanks
    GINTANI TUNED
    Aug 11 2007
    California
    It's not bad, you just won't be boosting at what you should be boosting at.
    Jun 26 2007
    Beverly Hills
    one more question, is it better to get the upgraded DV or just to Iforged, and whats the real difference
    GINTANI TUNED
    Veteran Member Four Rings SLYCAT's Avatar
    Sep 26 2007
    Augusta
    Get the forged DV if you're chipped, so you don't have to worry about it tearing again. If you're not then just get the upgrade DV. My .02 cents.
    Veteran Member Three Rings A4 JooN 2.0T's Avatar
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    Quote Originally Posted by enzoballin View Post
    lol iforged....so hows your 1k hp mustang??
    2007 B7 A4 2.0t Qtip Brilliant Black on Black -=- Revo Stg 2/SPS2 -=- Milltek Catback Labree Quads -=- Eurocode Testpipe -=- K&N Filter -=- Forge DV -=-RS4 Rear Sway -=- ECS Quick Spool Pulley -=- Neuspeed SS -=- 20% 3M Tint -=- Lamin-X Yellow Fogs -=- LED UV Blacklight Interior Lights -=-O.Z Ultraleggera Black w/ Yokohama S.Drives
    DUH! an Audi
    los angeles, CA
    i say go upgraded, holds more boost and it will not tore as easy as oem. if you wanna pick up a forge dv let me know I can try to find you a good deal installed since you are local.
    im picking up a forge dv, it also looks pretty =D
