Results 1 to 7 of 7
    Apr 09 2007
    New York
    B5 S4 Transmission Question/Problem...
    I was driving on the highway and all of a sudden I couldnt get my car into gear at all.. Clutch felt perfectly fine but could shift into gear at all.. I turned off my car to see if I could shift into any gears and at first, I couldnt shift into any gears but after a few seconds i guess it loosened up and i was able to shift into all the gears and was able to drive home without a problem.. I had this problem like 2 months ago and drove fine ever since but it happened again tonight? Can this be a bad pressure plate or a bad clutch slave cylinder?? I want to diagnose the problem before I bring the car to the shop and spend like $400-$500 to have them take apart the transmission..Thanks!
    Veteran Member Three Rings khj677turbo's Avatar
    Dec 25 2007
    Tampa
    Re: B5 S4 Transmission Question/Problem...
    throwout bearing?
    Current: 13 A4 P+ Sport, K04 etc, 18 SQ5
    Gone: 04 A4 1.8t USP 6-speed Avant
    Gone: 00 A4 1.8t K04'd
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    It sounds like the slave. The same thing happened to me intermittently. I bled it, and it works fine now (knock on wood). If you end up needing a new slave, I have one I bought but never ended up using since the problem solved itself.
    the homebrew'd s4
    Apr 09 2007
    New York
    I was thinking slave cylinder too.. I guess thats the cheapest thing to check first so ill do that first thing in the morning..
    Account Terminated One Ring
    May 12 2008
    ny
    Quote Originally Posted by dm3nace View Post
    i have a 6speed stasis tranny for sale( $2,200 ). i also have a regular 6speed tranny for sale( $1,600
    Veteran Member Three Rings mmxruffryder15's Avatar
    Mar 28 2008
    new york
    same thing happened to me like 3 weeks after i bought my S4 and i first my cousin thought is was the slave and the mechanic said the clutch was bad so we ordered a new clutch nd when we opened it up the clutch was fine...the flywheel was done so i ordered a new flywheel nd put in the new clutch any ways...better safe than sorry u kno
    Apr 09 2007
    New York
    my car officially died on me.. cant shift into any gears at all when the car is on.. When I turn the car off it can only switch to 1st, 2nd, 3rd gear... I was able to drive back home on 1st gear only.. I need to get the car checked up.. any good local shops that can do the labor for a decent price? Im located in 11364.. Oakland gardens, new york..
