I am the guy who installed them.
here you can see my arm as I am wiring:
The install was very simple. The halo's came with a lengthy, pre-wired harness, that I mounted just behind the faux-firewall. It comes with an inline fuse on the power side, and a 2 pole relay. I used one pole(single red-white wire) for the signal, which I spliced into his city light power wire, and left the other pole(single brown) open. The power/ground wires come with connectors installed to mount on the accessory terminals on the battery. I ran the harness through an unused grommet just behind the exhaust side of the motor, over the airbox, and to each headlight. If done correctly, and with the use of small zip-ties, no wiring is visible with the hood opened.
I will say, the wrong size connector was used in the relay main power wire(it was an 8 ga. wire in a 12-14 ga. connector I believe). That was easily fixed with a set of crimp tools to secure the wire.
I trimmed the clips off of the halo's provided and epoxied them to the inner housing. They have a black and white wire(visible in the first set of pics) that you can run back and down into the smaller opening for the high beam bulb. Then close the cover over the wire.
