Results 1 to 40 of 58
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Who needs paint? Black Vinyl goin FTW
    Well I started yesterday, took a break to party and then just finished a little while ago. It took me about 6 hours total to cover up all of the brushed aluminum with black vinyl. I did the front grill, sides, and the piece under the trunk. I bought 20 ft of vinyl that was 15 inches wide. I was kind of frugal with it and barely had enough to finish. Here are some rough photo's... I'll take some more when it is a little nicer outside and when I get the Ultraleggera's put on...
    http://community.webshots.com/album/563472629aEscHT
    Can someone tell me how I can post in the thread? My posting rules say: You may not post attachments
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    Re: Who needs paint? Black Vinyl goin FTW
    same way i would've do it, especially because it's not permanent... nice!
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    wow..... very nice. i might do this myself. the vinyl is adhesive, correct? how exactly did you do everything?
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    That looks good!
    I would resize those pictures though first. Then, get the exact location of the picture (will be something like www.good-times.webshots.com/photo/23734609.jpg, then put that inside of the image brackets which are {img} {/img} only [] instead of {}. The yellow picture button above the text field where you reply will do the same thing.
    Ignorance is bliss.
    Veteran Member Three Rings FlashA4's Avatar
    Dec 17 2006
    Formerly B7 A4 2.0T - The OG Flash Mobile / B8 A4 2.0T Quat - Baby Flash
    Orlando, FL
    Am i fully understanding this? you used actual vinyl? Like fabric vinyl? I certainly hope its marine grade. Regardless, from the pics I actually like what you did. I hate the chrome that goes around the car and would much prefer to have it painted black (or vinyl, in your case). Good job on the effort you put forth with this project.
    btw, i need a How-To pronto... im very curious about the walk through on this one.
    Mar 07 2008
    Audi A4 B7
    VA
    The vinyl is an automotive vinyl that I found on ebay. It is adhesive on the back. Here is the link to where I got it.
    http://cgi.ebay.com/ebaymotors/ws/eB...m=180241141595
    To apply it, I basically just cut strips the length of the area that I was doing and then laid it down on top of the aluminum. I then used a pen (and then part of a tap and dye set) to push down on the corners. I then used a blade to cut around the edges. Finally I used the tap to fold in the edges to make it stick on the back side. I took pictures of the whole process and think I am going to write up a DIY. However, that will come at a later date. For now I will just post some of the "how to" pictures on the webshots link.
    LAS, thanks for uploading those pics for me. Sorry, I deleted and reuploaded two of the pics because they had my license plate in them... I don't want any of you scoundrels finding me!!! muahaha
    Feb 12 2004
    HI.
    you don't post attachments on AZ, just get the "direct link to image" on the bottom right side of the screen on webshots, i used the 600megapixel size, then use it when you click on the little 'mountain' icon just above where you enter text.
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    holy shit that came out really good, looks exactly like the titanium package trim. definitely a better way to get that look without paint.
    Nov 15 2007
    im kind of scared i might cut up the paint like i did when i had to trim my lamin-x tails..
    Mar 07 2008
    Audi A4 B7
    VA
    Quote Originally Posted by supamannn99 View Post
    That was the only thing bad that happened with all of this... I got a little paint in a couple of areas. Just a thin line from the razor, but I was really sad when I saw it. You have to be very careful when doing this to make sure that you are barely pushing on it so that you only cut the vinyl and not paint... In a lot of places there is a nice gap so you are basically cutting vinyl with air on the other side and then you just have to use a tool to fold it up behind the trim to make it stick.
    Feb 12 2004
    HI.
    one thing i would worry about is that if you stretched the vinyl a little too tight when applied, after time in the sun and depending on the type/quality of the vinyl, it may lose moisture and shrink a little. time as in a year or two and depending how much sun your car gets. just a thought.
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    I would worry about it fading colors over time, but if it only took 6 hours! Nice work and an A+ for ingenuity!
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Nov 02 2007
    Albany, NY
    did you do the front rings too!
    2008 Ibis A4 2.0T
    May 10 2007
    Long island
    i need to do the front rings! i'm interested in this. any easy way to do this with the vinyl??
    Mar 07 2008
    Audi A4 B7
    VA
    Yeah, when I went to do this I was worried about the vinyl coming off after time as well as it fading. But at this time I can't really afford getting the trim painted since I just bought new wheels/tires and springs... It's kinda like, pay $500+ to get it painted and worry about it chipping or not adherring vs. $65 plus 6 hours work and hope it doesn't peel off or fade. At least if it starts peeling off, I can always patch it up (if it doesn't fade HA).
    And no, I didn't do the front rings... I don't think I can get the rings to be smooth enough for my liking. Anyone have a good DIY for painting the rings? I just need to get the rings painted, debadge it, get the O.Z.'s put on, and then paint the calipers red... then I'll be completely blacked out and have the look I have been dreaming about.
    Registered Member One Ring element498's Avatar
    Apr 06 2008
    2006 Audi A4 2.0T
    Springfield, VA
    Sweet! I have the same car and was wondering how this would look! I just ordered some myself..
    2006 A4 2.T Quattro | Stock (For now)!
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    looks good.
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Registered Member Two Rings Ski DraGoN's Avatar
    Sep 24 2007
    fl
    nice job!
    Mar 23 2008
    Colorado
    I really don't see why the rings would be any harder. Put the sheet over and put a relief cut in the middle of each ring. Stretch and burnish until smooth and trim 'em up. I may buy 1' of it just to try. It would be easier than removing the bumper and gill just to paint them. If it doesn't look good peel it off.
    Jan 06 2008
    Dacia Sandero
    Arizona
    Quote Originally Posted by scoobycarolan View Post
    Complete thread jack, where'd you get your APR flash done in Albany?
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    Veteran Member Three Rings Josh_877's Avatar
    Aug 24 2007
    Chicago Suburbs
    nice, i like how that looks. good job
    Jan 06 2008
    Dacia Sandero
    Arizona
    By the way, I like this mod a lot, but I'd be concerned about durability over time, especially since I live in the Northeast.
    Senior Member Three Rings ny2flb7a4's Avatar
    Nov 02 2006
    FL
    Good job.
    B7 A4 TQM Ibis Titanium pckg
    B9 SQ5 Ibis/Prestige/BO
    24 VW Golf R Lapiz 6spd
    Senior Member Three Rings oakenfolde's Avatar
    Jul 24 2007
    Las Vegas
    wow that came out very well...
    might look around in vegas for something similar
    2005 turbo Acura Rsx-s
    2007 Ibis White A4 Quattro S-line
    2009 Tahoe Z71
    2013 A5 S-line
    Registered Member Two Rings 80020vr6's Avatar
    Dec 19 2006
    2007 A4 2.0TQM (Ibis)
    Colorado
    Looks great. Keep us posted on whether or not it stays stuck around the edges or any other adverse condition. I heard about one guy who went over it with a heat gun very lightly. Don't know if that would help or not.
    Mar 07 2008
    Ft. Lauderdale
    did you use 3M adhesive vinyl? I just ordered some that is colormatched to my car. I am going to be doing the reflectors, filler plate, and the window trim. Did you try putting blue painter's tape on the paint as an extra layer of protection from the razor? Did you use a hair dryer or heat gun at all?
    Mar 07 2008
    Audi A4 B7
    VA
    Quote Originally Posted by R1NSE View Post
    I do not know what type of vinyl it was that I got. I posted the link to the ebay site in which I bought the vinyl a little further up in the thread. It was pretty much the only automotive vinyl that I could find. I didn't use any painters tape to protect my paint and therefore there were a few spots that I scraped a little bit of paint. I do not know how well the tape would work because I think it would be pretty hard to apply the tape to the areas that would need it. Also, you would probably end up cutting the tape and it would be a pain to try and remove it... Although I do suggest trying to use something to help protect your paint. I used a hair dryer on some of the areas, especially where I got any little bubbling. I think I am going to go over the whole thing with a hairdryer in the next couple of days to try and "melt" it on there a little better. For spots that bubble you can either pull up the vinyl and then reapply it (which was surprisingly easy and didnt seem to make the vinyl lose any stickyness). Also, there were a couple spots that bubbled after I had already trimmed the edges off... For these I heated up the bubble with the hairdryer and then poked a hole in the middle of the bubble with my razor and then flattened it out. Today will be the first test to see how it stands up to the heat and sun. The car is currently outside of my office baking in the sun while I sit here and stare out the window at it...
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    Quote Originally Posted by Glassnpowder98 View Post
    Gotta love Audis.....
    Pro work by the way, man - makes me want to get all DIY and try this. I also give an A+ !
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    where did u get the vinly from? PM me Also how does it handle when washing the car?
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
    Active Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    Hey how many feet did you order bro? I'm gonna try this out....
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    Established Member Two Rings STaSIS_2.0T's Avatar
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    nice work! looks great!
    STaSIS/GIAC ECU | ITG ProFilter | EvolutionRacewerks SMIC's | STaSIS exhaust | STaSIS/Koni/Vogtland suspension | STaSIS/Alcon 355mm Mono4 brakes | Volk CE-28 19x8.5 | Toyo T1-R 265/30 | O.Z. Superturismo GT 18x8 | Dunlop Wintersport 3D 235/40 | JHM short shift kit | ECS snub | RS4 rear sway | RS4 pedals | S4 shift knob | RS4 grill w/s-line chrome surround | VMR vent boost gauge | 034 Intake Pipe | CoolBoxMod | Hardwired 8500 X50 w/"OEM" mute button |
    Mar 07 2008
    Audi A4 B7
    VA
    Quote Originally Posted by 3.2some View Post
    I ordered 20ft originally and just barely had enough to finish, however I did waste a good amount with the cuts I made. I recently ordered 10 more ft to patch up a few places that I orginally messed up. One spot, I didn't overlap the two sections and some aluminum is showing. Also, the back rear small window (behind the rear doors) I messed up. You need to fold down the weather stripping on the bottom and shove the vinyl down in there or you will get some chrome showing along the bottom line.
    I advise anyone who does this, make sure you overlap each section by a few centimeters and make sure that all of the aluminum is completely covered because I have experienced a little bit of shrinking. For example, one section I did on the back window I just barely overlapped and it is beginning to pull apart a little bit due to shrinking. However, none of the vinyl has pulled or peeled off in any other sections, just where I connected two sections of vinyl. I've probably confused you by now, so I'll try to take some pictures when I get home from work today.
    Mar 07 2008
    Audi A4 B7
    VA
    Quote Originally Posted by Vito Roma View Post
    I have only washed my car by hand since I've done it and I haven't had any peeling. I really don't think you would have a problem bringing the car to a car wash either as the vinyl really sticks on there well.
    Dec 19 2007
    Escondido, CA
    thanks, I'll order 30 ft just in case
    V/R -Phil
    Mar 07 2008
    Audi A4 B7
    VA
    Alright... I realized that my description was horrible without visual reference... so here is a quick paint diagram of what I was talking about.
    1. Is the seam that I did not overlap enough. It looks fine in that picture, but after a month in the sun it has shrunk a little bit and is exposing some aluminum.
    2. Is the line (can't get it straight because my mouse at work blows) of weather stripping that you have to pull down and shove the vinyl down into. You can't really tell from the pic because the lighting isn't too good, but when it is in the sun you can see a thin line of aluminum showing through.
    Hope that helps...
    Dec 19 2007
    Escondido, CA
    the main thing I see being a problem is going around the curves, you have any advise on how you did that so that it wont leave any bubbles or cracks?
    V/R -Phil
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Am I seeing right? Did you actually cut this with utility blade? Looks like you were touching the paint below the trim?.
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    I just did my rings... Get 600 grit sandpaper, and sand them just to scuff them.. Then I just used promax brand gloss black enamel (4 layers)... turned out great.. Matches the plastic on the grill perfect. The only thing is that you must take off the grill in order to take the rings off, but they just snap right back in.. I did this mod when trying to install my FMIC (failed due to spline drive tool), and HID fogs(success!!!)..
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Mar 07 2008
    Audi A4 B7
    VA
    I just cut strips that were wide enough so that they would cover the curves. You just need to flatten them down so that you can see the curve and then cut away... below is an example of how i did the corner. On the bottom right, just make sure that when you cut, you leave enough excess vinyl to fold around the edge to the back. It will kind of bend up but it will be on the other side of the trim.
    Mar 07 2008
    Audi A4 B7
    VA
    Quote Originally Posted by ibiski View Post
    You are correct... If you see one of my posts towards the top of the thread, I mentioned that I did cut a little bit of paint. However, if you have a pretty steady hand and a sharp blade (I suggest changing your blade at least once to keep it sharp), you will not scratch your paint. Anyone who tries this, make sure that you are not pressing down against your paint. When you put the vinyl down over the trim and paint (see picture above) you will have a nice gap between the vinyl and the doorsill. There is plenty of room to cut and not hit any paint. Just make sure that you cut a little bit closer to the doorsill than to the trim so that you have enough vinyl to fold around the back of the trim to ensure that the vinyl will stick to the back.
