Results 1 to 10 of 10
    Active Member Two Rings SNOOK's Avatar
    Dec 23 2007
    08 A4 Avant
    So Cal
    Thumbs up A4 B7 2.0 Carbonio!!!!! Pics now up!
    SOLD
    Just took it off my 2008 Avant 2.0 A4 has about 5k miles on it, first $280 is the taker (OBO in a timely manner want this gone!). I'm in Pasadena, CA and you can pick it up or pay for shipping. Thanks!
    Dec 23 2007
    08 A4 Avant
    So Cal
    Re: A4 B7 2.0 Carbonio!!!!! Pics now up!
    Shipping to lower 48 US (shipping price ranges from 15-35 bucks for UPS ground insured for $375) All others not sure still.....
    if you want to calculate shipping costs, just go to http://www.ups.com and enter in using own packaging, shipped from UPS store, for shipment from 91101 to your Zip Code, 15lbs, $375 value, 10 Hieght X12 Width X18 Length
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    Why did you take it off?
    Dec 23 2007
    08 A4 Avant
    So Cal
    I just bought a condo...so I'm getting rid of my car options in return for using the $ for options for my new place.
    Dec 20 2007
    Colorado
    So how did it sound on the car?
    and do you have exhaust as well
    I just bought techtonics catback but
    am seriously considering a CAI as well
    Did you notice gains?\
    I know the debate on this one is huge
    but what about for you?
    I'm pretty sure we have almost the same car
    thanks in advance for your input!
    Dec 23 2007
    08 A4 Avant
    So Cal
    Quote Originally Posted by bblume View Post
    I have an AWE exhaust...With the Carbonio, the sound the diverter valve makes is more pronounced and you can hear the car sucking in air and releasing it. It's great if you like that and may make you feel as if your car has gained in less restricted airflow or even higher horsepower numbers. I don't think anyone will ever feel gains adding this. I'm sure the product has been tested by the maker and if this thing added any horsepower they'd be selling that fact hard to the consumer. If anything, you may be getting more airflow.
    Dec 20 2007
    Colorado
    Do you still have install instructions?
    or is it so easy I shouldn't even be asking?
    and what about Paypal?
    or
    Dec 23 2007
    08 A4 Avant
    So Cal
    I never had the install instructions, I had it installed and removed it myself. It was very very easy to remove. It seems as if it mounts up much easier than the factory box because I re-installed that. All you need to do to install this is remove the fact airbox, screw the 2 pieces that make the heatshield together, this is attatched using the factory bolt on the inner fender panel. Then, attach the inlet tube through the heat shield (2 bolts), attach the filter. Fianlly, attatch the Carbonio hood (3 srews) and attach the flexible ducting to the Carbonio hood. Done. You'll need a 10mm, 11mm and 12mm wrench and i think it's either a 2.5 or 3mm Allen for the small screw in bolts. Yep, accepting payment for this through PayPal. Thanks!
    Dec 20 2007
    Colorado
    PM Sent
    Dec 20 2007
    Colorado
    Payment sent!
