1) When going to a purly oil lubricated turbo, what do people do with the coolant lines? Is it possible to cap them, or do you just run a closed coolant line to connect form the coolant rail above the intake to the block?
2) When making a oil feed line, what 'part' or adaptor do you need to adapt the line to meet with the oil cooler? Sorry, i don't have a picture, i spaced on that on.
3) When creating a oil return, is there a specific peice that you use to attach to the to the oil pan? or do people use the factory piece and attach a hose using a hose clamp? (Dosen't sound right to me, but i guess it's possible)
4) Where does this guy attach to?
5) When using an aftermarket fuel rail, does it matter which end of the rail is fuel feed and fuel return? I.E. can you run the fuel feed to the 'port' on the fuel rail at the front or the motor, or do you need to run it to the back 'port'?
Thanks in Advance!!!
