Results 1 to 15 of 15
    Senior Member Two Rings treemolecule's Avatar
    Jan 13 2008
    04 1.8TQ6M(^^sleepy car)
    Charlotte, NC
    help me, i'm retarded
    Alright, i keep throwin a cel no matter what, it's always when there's at least some charge air diverting. I did some inspection and found a huge rip in my DV hose, my question is where can i find a dang replacement? i feel like absolute idiot, i think maybe the samco hose kit may include it but i dunno, thanks
    [B]APR Stage 1+ and Snub Mount
    034 DensoLine Engine and Tranny Mounts
    GReddy Turbo Timer
    Forge TIP (RED)
    Dec 06 2007
    Re: help me, i'm retarded
    ^^go to any autoparts store measure the hose and ask for a VAC hose in that diameter and in that length and switch it out!
    -Kirk
    BetaAlphaTau Member #58
    Jan 13 2008
    Charlotte, NC
    it's molded into a sort of U shape though
    GReddy Turbo Timer
    Forge TIP (RED)
    Dec 06 2007
    ^^pull it off, and there's a part # on it go to the dealer or something and ur set, or check my thread and see which one it is!
    http://www.audizine.com/forum/showthread.php?t=201965
    -Kirk
    Jan 13 2008
    Charlotte, NC
    woo, thanks man
    GReddy Turbo Timer
    Forge TIP (RED)
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    you can get a radiator hose that has close to the same bend. When I relocated my DV thats what I did so everything fit cleanly.
    Jan 13 2008
    Charlotte, NC
    good call J, what BOV/DV you go with?
    GReddy Turbo Timer
    Forge TIP (RED)
    Aug 28 2007
    Quote Originally Posted by treemolecule View Post
    Forge 007 DV. Like it a lot, but just for fun I think I'm going to buy a 004 BOV this summer. Because I can access my DV very easy now, so changing it In and out will not be a problem.
    Jan 13 2008
    Charlotte, NC
    i had a turbosmart splitter type, it did very well as a BOV and i threw 1 cel only, and after i erased it it never came back, but i shot that BOV to hell when i chipped up, so during the interim i'm running my stock DV, is that forge good for holding 1-1.5 bar?
    GReddy Turbo Timer
    Forge TIP (RED)
    Aug 28 2007
    Both the Forge 004 BOV and 007 DV are good for that much psi plus some. You will just need to run different springs (stiffer or softer) Depending on how much boost you run. And my advice would be to order a new DV or BOV now (whether you want sound or better performance) before the stocker shits on you.
    Here is a link to Forge's web page showing what springs to run for what psi you are running. Im guessing your the yellow spring.http://www.forgemotorsport.com/conte...roduct=FMDVTUN
    Jan 13 2008
    Charlotte, NC
    jizzle, sorry man for the ?s but what diameter was that rad. hose that you used?
    GReddy Turbo Timer
    Forge TIP (RED)
    Aug 28 2007
    ^^no problem, I think it is a 1" inner diameter. But what I did was take my diverter with me to make sure the hose would work. I went to Advanced Auto and the dude let me go in the back and look around till I found what I needed. If you can't find exactly the right bends you need, something close should work. Or you can piece some rad. hoses together with PVC connectors from Home Depot.
    Veteran Member Three Rings sadpandas's Avatar
    Oct 05 2006
    b6 a4 grocery warrior
    High Atop The Eagle Rock
    Retarded people should wear helmets so if you dont have one go get one so we aren't so worried about you when you are outside playing. it is 1" in diameter (if your broke you can use fish tank tube... KIDDING). Homie depot FTW.
    P
    b6 a4 avant-blk/blk
    2010 Kenny Anderson 'Bar' series, Royal O.G. trucks, 54mm Girl Streamline wheels
    Jan 13 2008
    Charlotte, NC
    Yea I have a heat taped foam helmet with a 2" over top dead center eye hole mod, and slobber slots, so I'm good hehe thanks though, help a retard out and tell me what FTW means hehe
    GReddy Turbo Timer
    Forge TIP (RED)
    Oct 05 2006
    For The Win! (i spend too much time on the intrawebz). :( seriously.
    b6 a4 avant-blk/blk
