Results 1 to 15 of 15
    Senior Member Three Rings Avant1.8BT's Avatar
    Nov 05 2006
    mycar
    Missfires...No Start..
    Every 2 days or so my car will not start. i will be driving the car fine all day running around town and such then i will park it for about 3-5 hours then it will crank over and almost start. the plugs are sparking, wet and i have compresion but the car wont start. if i let it sit for a few more hours around 7-9 then it will start up after a lot of cranks. the 2nd time this happened my check engine light came on flashing but they went away after about 2 miles of driving. i went to autozone and got a qucik scan and had missfires from every cylinder. i also notice the misfires happening when i really get on the car around 5800rpms or so. Im going to borrow my friends vag-com to get the actual codes, hopefully that will help out.
    TIA.
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    Re: Missfires...No Start..
    do you have a boost gauge, what's your vacuum like at idle?
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
    Nov 05 2006
    mycar
    Quote Originally Posted by creechsa4 View Post
    vacuum is 16
    Nov 05 2006
    mycar
    im new to vag-com but here is what i got after scanning....
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 8D0 907 557 P
    Component: 1.8L R4/5VT MOTR HS D04
    Coding: 06201
    Shop #: WSC 06325
    8 Faults Found:
    17968 - Maximum Engine Speed Exceeded (Engine Warranty VOID! :-)
    P1560 - 35-10 - - - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - - Intermittent
    16685 - Cylinder 1 Misfire Detected
    P0301 - 35-10 - - - Intermittent
    16688 - Cylinder 4 Misfire Detected
    P0304 - 35-10 - - - Intermittent
    16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    P0116 - 35-10 - - - Intermittent
    16686 - Cylinder 2 Misfire Detected
    P0302 - 35-10 - - - Intermittent
    Readiness: 0000 0001
    Address 03 -------------------------------------------------------
    Controller: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D00
    Coding: 0273004284
    Shop #: BB 24334
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller: 8L0 820 043 D
    Component: A4 KLIMAVOLLAUTOMAT_D75
    Coding: 04142
    Shop #: WSC 06325
    Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8D0 919 910 P
    Component: B5-KOMBIINSTR. VDO D05
    Coding: 02242
    Shop #: WSC 00000
    Address 35 -------------------------------------------------------
    Controller: 8L0 862 257 N
    Component: CV-Pump D10
    Coding: 16204
    Shop #: WSC 06325
    6 Faults Found:
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    00991 - Interior Lights
    28-00 - Short to B+
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00102
    Shop #: WSC 06325
    End -------------------------------------------------------
    Jan 06 2005
    san diego
    thats decent vacuum. thought you might have bent some valves for the inconsistent starting. run a compression test to see your motor condition. you said your plugs were wet...
    Jan 06 2005
    san diego
    oh yeah slipped my mind, maybe your icm is on its way out.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    Coolant temp sender over fueling on cold start would be my guess, change that and the plugs and you are golden
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Feb 27 2005
    North Wales, PA
    my bet is the coolant temp sensor too. when my was on the fritz my car would not start.
    Registered Member Two Rings
    Dec 09 2007
    Massachusetts
    Thanks for the fast responses, my coolant temp gauge stopped working recently so it makes sense it would be bad. any idea on my problems at higher rpms? its seems to missfire ...any thing i can log with a vag-com to help?
    posted on friends name..still Avant1.8Q
    Feb 27 2005
    North Wales, PA
    what plugs are you running? try bosche f6 dtc. they cleared up my misfires.
    Nov 05 2006
    mycar
    Quote Originally Posted by Poopie View Post
    NGK BKR7EIX, i had a set of oh Bosch Super R1's in before or something..
    Feb 27 2005
    North Wales, PA
    i had the 7eix's before they misfired a lot. worst $30 I ever spent on plugs.
    Nov 05 2006
    mycar
    yeah did you have the missfires in high rpms? then when you switched to the bosche f6 dtc they cleared out?
    Feb 27 2005
    North Wales, PA
    yeah any boost beyond 19 psi and high rpm it would studder and miss quite a bit. They just seemed to blow out. Then i switched to the boshe plugs and they were awesome on the street. They missed ever so slightly at 7500 on the dyno, but you would never feel it on the street. I think it had something to do with the way the dyno loads the drivetrain.
    Nov 05 2006
    mycar
    yeah when i hit 22-25lbs it would start to missfire. hopefully i can find the plugs locally, reall wanna take my car to the track soon.
    thanks for the help poopie.
