Results 1 to 10 of 10
    Dec 05 2006
    So. Cal.
    H&R 10mm spacers finally on!
    Alright, so I finally got the correct spacers. I only was able to pick up the rears as the fronts have yet to arrive. I installed them yesterday and took the car for an evening cruise and they drive perfect. Granted they are on the rear, but nonetheless they are good to go.
    Since the hubs are prone to gathering rust, I coated all the surfaces that could eventually become rusty with some white lithium grease. I used a wheel brush to take off the rust that had gathered on the hubs before reassembly.
    Remember 150mm o.d.. The part number is under note #24 on H&R's site.
    be reminded that these were just some really quick pics right after it came off the jacks and before it was driven. I'll get some better today at the Irvine Meet.
    Dec 20 2006
    CAN
    Re: H&R 10mm spacers finally on!
    Nice pics, thanks! Just need a little drop and you're there man.
    I can't remember if you ordered these through ECS or not.
    emilyPay.com - Revolutionizing payment processing by making transactions simple, secure, and more reasonably priced.
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Senior Member Three Rings snowbird's Avatar
    Nov 20 2007
    '04 S4, '11 Q5, '90 Corrado, '96 911 C4S
    Toronto ON
    Looks good!
    Just a word of caution: be careful when using grease/anti-seize on wheel bolts and hub mating surfaces. Lug torque should be applied "dry", since grease on threads or mating surfaces can temporarily inflate the torque reading. As the grease squeezes out from the thread and hub mating surfaces, the actual torque will be less.
    Did you get longer bolts too?
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by snowbird View Post
    Looks good!
    Interesting, thanks for the heads up. I got my torque wrench in the trunk and will recheck after a few miles. I didn't grease the bolts, only the rusty hub and accompanying mating surfaces but will surely recheck my torque settings aftera few miles.
    I used longer bolts but they didn't have the little moving ball sockets like the stockers do.
    Taking the car to a audi meet this afternoon and the rive should help settle the suspension a little from the lift. I want to lower it but my funds won't permit that mod yet.
    Jan 14 2008
    B8.5 S4 - 6MT Sepang/Panda
    Calgary
    Looks good! That's the way it should come from the factory.
    Registered Member Two Rings mus27's Avatar
    Mar 17 2008
    B6 S4 Negaro
    what type of golf clubs are those in the background? looks like a taylor bag. how often do you get to play.
    Dec 05 2006
    So. Cal.
    lol, when i looked at the pics, i knew that someone was going to chime in on them. It's the lightweight Ping bag, Ping Eye Copperhead's and a Taylor Made Driver. I haven't been out in a while but the last time was with my Dad and I shot a few stroks over Par. Best game to date as I usually hack up the course.
    Quote Originally Posted by CanuckRS4 View Post
    ordered them through Impex. A local shop here in San Gabriel, CA.
    Veteran Member Three Rings Speedymon's Avatar
    Aug 27 2005
    2004 S4
    San Antonio, Tx
    Looks good. I was planning on using anti seize when i put mine on. That stuff is tough to wash off.
    Imola_Jon's supervisor...
    Active Member Two Rings <-JOEM->'s Avatar
    May 16 2008
    '64 VW Bus, '07 Audi RS4
    Sarasota, FL
    awesome. got any before and after shots from directly behind your trunk?
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by <-JOEM-> View Post
    It's so subtle that it is barely noticable. From your other thread, spacers are better than no spacers at all, lowered or not!
