Results 1 to 6 of 6
    Oct 26 2005
    St Paul
    FS: Palm ProDiag (VAG-COM)
    ProDiag software/palm pilot - Used but works fine. Includes: Palm m500, charger cradle (not pictured), OBD II to Palm cable, and ProDiag software (no original disks). Does just what a VAG-COM does in a handheld format - has served me very well for the past couple of years. It is so easy to just carry along. NOTE: I bought this used and did not receive the original disks - I contacted ShadeTree software (who made this at that time) but they were no help in providing them. I'd be happy to demo it for you. (Located in St Paul, MN) SOLD
    Please email me with any questions (or pm is fine).
    Stuff I need:
    RS4 Accordian hose
    Spacers for RS4 injectors
    Wideband 02
    Sean
    Veteran Member Four Rings dubenvy's Avatar
    Oct 22 2006
    '14 A4 2.0tQ (wifey)
    Odenton
    Re: FS: Palm ProDiag (VAG-COM)
    how does this compare to VagCom in the amount of stuff you can do?
    USP CLUB MEMBER #41
    <<Insert Clever Signature Here>>
    Oct 26 2005
    St Paul
    I think it is almost exactly the same. You can re-code, monitor measuring blocks, log, view and clear codes. I'll try to get a better description though. Logs multiple channels, etc.
    Oct 26 2005
    St Paul
    From the manual:
    What Is ProDiag?
    ProDiag is a software program that runs on your PalmOSĀ® device and allows
    you to diagnose problems, monitor behavior and modify parameters in the
    different Electronic Control Units (ECUs) found in your VW, Audi, Seat or Škoda
    vehicle. ProDiag is designed to be replacement for the official factory diagnostic
    tools used for troubleshooting, monitoring and coding ECUs supporting OBD or
    OBDII from 1990 to present.
    The ProDiag software has thousands of Diagnostic Trouble Code (DTC)
    messages and more than a hundred different equations - all compatible with the
    official VW Group vehicles. The interface is intuitive and easy to use. PalmOSĀ®
    devices are small, unlike the bulky V.A.G. 1551/1552 and VAS 5051/5052 tools
    and, best yet, ProDiag is just a fraction of the cost of these tools.
    If you want more info, I can send along a PDF of the user manual.
    Thanks,
    Sean
    Oct 26 2005
    St Paul
    Bump - would cost $400+ to duplicate with VAD Mobile!
    Oct 26 2005
    St Paul
    Sold!
