Results 1 to 16 of 16
    May 13 2008
    Brooklyn
    Did I do damage? sorry for semi-long read
    Hey everyone, I got my A4 quattro 2.0T about a month ago brand new from the dealer with about 60 miles on the clock. I currently have 800 miles on the odometer. Although the car drives perfectly just like the day I brought it home with no problems Im still worried that I may have done some kind of damage by being a complete idiot and ignoring the fact that this brand new engine needs to undergo a break in process. I understand that the appropriate thing to do would be to ride easy for about 1000 miles but I seem to put the gear shift in S every chance I get and just punch the gas, and I've been doing this pretty much since I got the car. I just recently realized how amazingly stupid this is and stopped. My usual practice is to put it in S, hit anywhere from 40-60 and then switch back. Can anyone shine some light on the type of damage I may be doing. Or is it possible that maybe my engine is fine and Im worrying to much?
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: Did I do damage? sorry for semi-long read
    Do you keep it under 3k until it warms up?
    -Kris
    May 13 2008
    Brooklyn
    well Its auto so Im not really touching red line but the car is usually running for about 10 minutes before i even get to the highway so I would say its warmed up.
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    I would stop doing that although the break in period is almost over so I guess it doesn't really matter anymore.
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    I have an auto was well .. I usually let it idle then I take off but I have it in the tip mode where I can control the revs not to pass about 3.5k and no more than 5psi on the boost gauge. When it reads that its at temperature I let it rip! better safe than sorry .
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    I wouldn't worry about it, you weren't beating on it that badly. Just think, all of the demo cars Audi uses and the people that demo them... you know that 75% of them are flooring the brand new car up until redline, and it's not like those cars have significant damage and aren't going to last or something.
    Just start driving it easily until your recommended break in period is over, and you will be totally fine.
    Ignorance is bliss.
    Oct 29 2005
    10speed
    San Francisco, CA
    thats how your supposed to break in an engine... When I built my 2.0, I ripped it from day 1
    - Clint
    Established Member Two Rings KokujinTensai's Avatar
    Aug 28 2007
    2011 Volvo C30
    Chicago
    Quote Originally Posted by Phrost View Post
    +1
    you all have NO IDEA. I think its funny how people obsess about 'breaking in' a car. When i had my S4 delivered, it essentially came right off the truck and the next day i tracked it. I drove it hard for about the first 500 miles and a lot of that was the track. The car performed flawlessly. You guys should put more faith in the nice people who engineered and built your cars.
    ________________________________________
    "When the going gets weird, the weird turn pro."
    -Hunter S. Thompson
    Junior Member Two Rings Kuang87's Avatar
    Apr 01 2008
    Chicago
    well it seems like i have fried my turbo and ive only had the car for 9 months.
    07' Silver A4 2.0T Quattro Tiptronic
    H&R Coilovers, H&R Rear Sway Bars, Carbonio CAI,
    Milltek Exhaust, APR 93 Chip, APR FSI Fuel Pump, Forge DV, 20% Tint,Hi-flow Milltek Cat,
    AWE FMIC, and Alcon BBK
    19" Champion Motorsport RF62
    19" HRE M40
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    The most important thing to look after in the break in period is the brakes for about 300 miles. Modern engines + modern oils don't really need a lot of break in. I chipped mine with 300 miles on it and even though I didn't floor it every time, I did "test" the chip several times a day every day ;)
    Back in the old days new cars had engines so tight that they had a hard time turning when cold...
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    Today cars come tested from the factory. Things change over the years. better oils, engines, & parts make for better more reliable car. I have not broken a car in for the past 5 years. I drive them like I would if they had 20,000 miles on them.
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Nov 12 2007
    Grand Junction, CO
    The reason you break it in is to get the pistons to seal and lubricate properly. If you run the car hard when it's brand new, the proper seal and lubrication may not occur and you could have big problems down the road. However..in your case, since it's an auto...I wouldn't worry about it too much.
    Aug 20 2007
    2006 Audi A4 2.0T Tip'
    Fitchburg, MA
    Quote Originally Posted by AudiWxGuy View Post
    There are also very reupatable opinons that claim the exact opposite.
    Some people say that the only way to seat the rings is to drive it like you stole it.
    Registered Member Two Rings Ski DraGoN's Avatar
    Sep 24 2007
    fl
    You fucked it up.
    Registered Member Four Rings 4-tified's Avatar
    Sep 18 2006
    A4 2.0T Quattro
    Chicago
    Engines are broken in at the factory once they are assembled.
    Even if you somehow manage to get a car with 0 miles on it, the engine has already been fired up, warmed, and run to redline.
    Make sure you "bed" or break in your brakes for best performance.
    Tires even need heating and cooling cycles to "break in", but most people are unaware of that as well and yet everything is fine.
    Apr 14 2008
    2008 A4 SE Quartz Gray 2.0T
    Is 1000 miles when the break in is completed? Can you rip away after 1000 miles without fear?
