Results 1 to 11 of 11
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    What to do about spark blowout?
    Have BT from eurocode, Timing 6, boost 9, and tried various fueling, currently maxed out. It doesn't pull any CF, but on anything but a cool or wet day, I get what appears to be spark blow out (not knock) above 4500rpm. Some days I get it, some I don't. Note that it doesn't happen at full load at other rpm, just above 4500 or so. I put a fresh set of coil packs in, but it didn't change anything. I'm running the side electrode plugs that came with the turbo.
    Ideas? just too much boost without meth? I wonder if some Iridiums a couple steps colder than stock would do the trick? (I sure wish there was better ignition solutions available).
    I tried lowering the timing, but hate how it runs on anything but 6, and it still does it. Lower boost works ok, but what's the fun in that....
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: What to do about spark blowout?
    Change the gap to .029 and see if it helps. Are the plugs the Bosch FR5-DTC? You need to change them every three months or 3,000 miles for optimum performance.
    Aug 26 2005
    Less boost and more timing advance, if properly ballanced, should provide about the same torque that you are realizing now, without the spark blow out experienced with the boost and timing settings you use currently. 034 EFI's website has high output ignition setup available.
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    if your air fuel ratio drops below 11.5:1 you will probably see blowout. Unless you are talking high rpm's which would be odd you shouldn't be running richer than that unless you are huffing phunny gas.
    usually the rich misfire is just from poor tuning too rich but of course your wideband would tell you that (along with whacky EGT's to back it up).
    gap and "R" coilpacks for sure. Too cold of plugs maybe but i run BKR7E on my stage 1+ all winter long without a misfire.
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Dec 25 2004
    Earth
    Have you tried the Bosch F5DPOR...
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    FR5DTC's fixed it for me, I had aproblem with it a long time ago. I was having some random misfires but strangely they went away after I put the cams in.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by MikTip View Post
    Not o good mix with the GTRS. I got tons of blowouts with them.
    Veteran Member Four Rings 1point8teeNW's Avatar
    Nov 11 2006
    North Webster, IN
    What does spark blowout "feel" like? As in, when driving under load does it feel like multiple misfires?
    Current - 2004 Pontiac GTO 6M *FOR SALE*
    Looking for - B6/7 S4 TIP or 6M
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    most people call it surging
    Veteran Member Four Rings Sablea4's Avatar
    2018 Suburban, Husqvarna riding mower :P
    Charlotte, NC
    like everyone else said. your plugs need to be gapped a little less
    Current: 2017 Audi Q7 Premium Plus. Carrara White with Nougat Brown interior. APR Stage 2, RocEuro intake, BMC filter
    Sold: 2005 Audi A4 Ultrasport Avant red with manual transmission USP CLUB MEMBER #6
    Sold: 2004 VW R32 Deep Blue Pearl
    Sold: 2010 VW CC Shadow Blue Metallic manual transmission
    Aug 26 2005
    2nd.
